Question about Alpine IVA-D901 Car DVD Player
After i hook everything up to the brain and my RCA wireing i can hear my sub, but no front or rear everything in my car is amped all the ams are on and work fine, just cant hear audio out of the AUX ports on the brain, can u help ??
  • matt1520 Feb 08, 2010
    thanks for your detailed help there was a switch on the bottom of the brain that hat to be switched over you tool thank god i dident take your useless advice. :S
    Problem Solver:
  • 13 Answers
The rca r blowed get a new radio
Posted on Feb 08, 2010
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Wireing diagram to hook up amp sub and 4 speakers
Here's the color codes for the wires.
Blue=power antenna
Blue/white=remote turn on for amp
Red=ignition
Yellow=battery
Black=chassis ground
Grey=right front (+)
Grey/black=right front (-)
White=left front (+)
White/black=left front (-)
Violet=right rear (+)
Violet/black=right rear (-)
Green=left rear (+)
Green/black=left rear (-)
RCA Connections:
Red=right rear to amp
White=left rear to amp
And that should be all the wires. Good luck!
Sep 26, 2010 | Alpine TDM-7582 Cassette Player
There are no RCA recivers on the rear of the deck. I am trying to hook up sub woofers, and not sure how to get sound to them. Can you help? Maybe there is a cable that converts to connect the two. I also...
you could convert the front or rear speaker wires to rca at the amp. by soldering on the rca plugs.if you converted the fronts then the front speakers would no longer work as you were taking the feed for them to the subs.
Sep 27, 2009 | Panasonic Strada CN-NVD905U GPS Receiver
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
I have a kenwood head unit with 3 rca outputs,front,rear and sub.my crossover is a kicker kx3 and it only has front and rear in and front,rear and sub out.my question is how do i hook up the crossover...
No. I would recomend running front and rear to the crossover. Use the sub out on the deck so you have total control of subwoofer output at your fingertips. Your deck should have at LEAST an 80hz crossover built in. Any further fine tuning can be done at the sub amp.
Larry T
Winona Lake,IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 28, 2009 | Car Audio & Video
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine IVA-D901 Car DVD Player Logo
53 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
