Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Our TV has been splitting itself into three horizontal section with each section having its own vertical lines. Now today it blacked out on the right third of the screen for a brief moment, then displayed a left and right display with their own horizontal lines and one larger black line down the middle separating the two. We've also had times where the faces on people are green. Can I get a schematic for this tv and possibly fix it myself? If it simply means the replacement of a chip that controls the vertical sync. I know I can probably do that.
  • 11,361 Answers
Try cooling the LCD controller board (TCON) with small fan or use electronics freeze spray. See example of failed LCD controller here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Posted on Feb 09, 2010
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
TV BLACK SCREEN WITH THE POWER ON.
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
May 28, 2009 | Philips 32RF82S TV
Fujitsu p42hha30ws
Black vertical line indicates horizontal deflection section not working. Change horizontal linearity coil the problem is fixed
Jul 24, 2008 | Fujitsu Plasmavision 42" TV
Screen Smaller on Orion1934" TV
Hello Falken94,
Your TV is losing what is called vertical deflection. This might be caused by the vertical coupling capacitor going bad, or by the vertical deflection coil on the yoke transformer going bad. In any case there is not enough vertical deflection signal getting for the vertical output section of your TV to the vertical coils on the yoke transformer. I would suggest that you get this looked at by a qualified TV technician, due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
Jun 19, 2008 | Orion1934 19" TV
Tv not showing a picture
Hello e26pitts,
If the line is horizontal then it could be a problem in your vertical deflection section, if the line is vertical then the problem is in your horizontal deflection section. Now for a little more detail.
If Horizontal line is present the vertical section of the yoke transformer is nit responding to current flowing through it due to being open, or the vertical coupling capacitor is open, or even the vertical drive transistor might be defective.
If Vertical line is present the horizontal section of the yoke transformer might be bad. Now this gets kind is easy in a way, because the yoke would be the sole cause of your problem here (maybe there is some circuitry doing some horizontal coupling check that to) because the horizontal section controls other functions that would also respond if this were a horizontal drive issue. In any event these problems should be checked by a qualified TV technician, I would suggest that you take the TV to a repair shop to have it worked on.
I hope this helps
Thank you,
Shuttle83
Mar 21, 2008 | Televison & Video
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
421 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
