Question about Matrix 226R (VPR226R) PC Desktop
I would like to know if my pc can be up graded with a water cooling system? if so, kind of cooling system should i get? Full ATX motherboard model#LAD845PEBT2V1 intel pentium 4 3.06GHz with hyper-threading tech. 512K cache,533MHz FSB ddr333MHz system memory 2 120GB (7200 RPM) ATA/hard drive's Creative labs sound blaster live 5.1 sound card intel on-board 10/100 networking
  • 488 Answers
Why ??? A water cooling system will not improve anything.. Just make sure that you have decent heatsinks and fans fitted with case fans that both draw air into the case and push it out. I run a quad core pentium with an Nvidia NX graphics card, 3 gig ram and five hard drives. I use five fans in all and my case temp has never gone above 44 degree's even when it is 40 degrees ambient. So, use decent heatsinks and fans and you should not have any problems..
Posted on Feb 07, 2010
12v ATX Power Connector connected to series GA-81HXP motherboard and CPU only causes ATX power supply to shutdown. Disconnect 12v ATX connector, back to normal.
"To ensure suffiient power can be supplied to your system, it is
recommended that a power supply of good quality be used. If a power
supply is used that does not provide the required power, the result can
lead to an unstable or unbootable system."
Apr 13, 2015 | Gigabyte Computers & Internet
Where on my motherboard do I plug in the 2 fans that came unplugged while cleaning?
Here is a detailed layout for the fans for your motherboard:
This is a part from page 52 from the Asus manual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 07, 2011 | ASUS M4A79T Deluxe - Motherboard - ATX -...
What is the motherboard form factor of the Sony VAIO PCV-J120 PC Desktop motherboard?
Micro-ATX (mATX, or MATX)
To be sure there is a guide to use.
A full ATX form factor motherboard measures 12 inches by 9.6 inches. 305mm by 244mm
(9.6 inches is approximately 9 and 9/16ths inches)
A Micro-ATX form factor motherboard measures 9.6 inches by 9.6 inches. 244mm by 244mm
http://en.wikipedia.org/wiki/Motherboard_form_factor
(Scroll down)
Regards,
joecoolvette
Dec 12, 2010 | Sony VAIO PCV-J120 PC Desktop
I have to know the coolest motherboard, the high tech kind of motherboard and its function.
You dont say what size format, Full ATX, Mini ATX, Micro ATX.
Intel or AMD.
Most High end motherboards costing over £200 look very cool and exotic.
Have a little search on google, Custom PC has some nice reviews http://www.bit-tech.net/hardware/motherboards/
Sep 23, 2010 | Intel D845GVSR Motherboard
I need a new motherboard for my computer. currently it has a ASUS PTGD-LA motherboard. does it matter what kind i replace it with?? I have an hp pavilion a1020n desktop
Information about the stock motherboard is here if you want to compare it to possible replacements. It doesn't matter what board you get as long as it fits (micro-ATX style) and can support the drives you have (enough IDE and SATA connectors). Also, if you want to keep your current memory and processor, you'll need to find a replacement that supports them. Finally you need to make sure that you stay within the ratings of the system power supply, unless you plan to upgrade it.
Hope this helps. Thanks for using Fixya!
Mar 04, 2010 | HP Pavilion a1020n (PS583AA) PC Desktop
Machines T1862 PC Desktop I need to know if an
Your cabinet doesnt support the full range ATX size motherboard..
It supports onyl Micro ATX and BTX motherboard..
Please leave me comment, if you need further assistance
Please rate this solution
Rnj VinodKumar
Dec 15, 2009 | E-Machines T1862 PC Desktop
I just bought this computer. It has 1 gig of DDR 667 in one of the two slots. How much can I up=grade it to? Is this the correct ram/ Thanks.
My best advice is to go to www.crucial.com and run their System Scan Tool.
It will tell you what you have, what kind it takes, what the max is, and a few other things too. It works well. Go to the site above and click on the "scan your computer" link. You have to accept the download, but it is safe. I've used it many times.
Thanks for using Fixya.
Wayne
Dec 01, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
List of cpu support for pga 370 motherbord
The 810E Micro-ATX can only support the following processors
Intel Pentium 3 / Celeron
Jan 31, 2009 | Intel FC-PGA2 Tualatin Adapter for Socket...
Matrix 226R (VPR226R) PC Desktop Logo
74 people viewed this question
Top Matrix Computers & Internet Experts
David Payne
David Payne
Are you a Matrix Computer and Internet Expert? Answer questions, earn points and help others
