Question about Microsoft Xbox 360 Console
Xbox 360 - red lights (2)
Okay I am so frusturated with the thing is going to be a boat anchor....
I have taken it all apart..removed the xclamps and used screws and washes as indicated. I didnt put all the plastic covers on it instead just tested it without the bottom and top covers.
I plugged it in and the fans ran for a few seconds and then stopped..now the power lights indicate 2 red lights and the cord from the wall to the xbox is orange. It was three at one point and now is three red lights and cannot stop the fans because tey stop themselves..
Someone PLEASE help..i have tried backing up screws so not too tight and still same problem...PLEASE give me some ideas..cleaned all the goop off the cpu and gpu made mirror shine and put new arctc silver paste on and NOTHING>..
  • krazykendall Feb 07, 2010
    I opened the case so it doesn't matter at this point because I voided the warranty. I just need to fix this thing and appreciate your assistance but please I am hoping you can just advise me of what i can do.
    please help ,me i keep taking it apart cleaning surface to mirror shine and then putting new paste and mounting. Please I need to repair it for my son
  • 111 Answers
I also had this problem, You should tigten the screws a bit further. If you will get 2 lamps, it still isn't tight enough.
Posted on Apr 21, 2010
  • 767 Answers
There is a possibility that your heatsink is touching a component
and causing a dead short . , remove all the screws and just
place the heatsink on top of the chip ,making sure that they
are flush down and level . no screws . Power on and if your
fan start and stays on , your in luck , now put the screw in
finger tight and see if your console fan speed stabilizes.
all advise accordingly if you get to this stage.
Rob
Posted on Feb 10, 2010
  • 827 Answers
Ok heres the scoop, i had a xbox halo3, paid lots for it, then went on xbox web site and checked on if i had registered it , i guess that i did not , well long story, i found that it had a warrenty, sent it in to xbox, sent it back in 2 weeks with a limted warrenty, but it was for the rings of death, your problem may have been caused by over tighting of the screws that you installed, i have now repaired 9 units, and all start with rod, i make sure that they are not under warrenty, then i take them apart, do the fix, and so far all are still working,try it again but let the unit heat up, then apply the paste, then put the heatsinks back on loosly, i have had to redo this only once other time.
Posted on Feb 09, 2010
  • 281 Answers
This can be caused by the unit overheating. Once this happens it shorts out the unit causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Microsoft and see if the unit is still under warranty.
Posted on Feb 07, 2010
Xbox xclamp mod
need a new power block or your board might be fryed :S
Jan 07, 2012 | Microsoft Xbox 360 Console
Xbox has got one red flashing light bottom right on the ring
this is caused by the graphix chip solder connections coming apart. Due to the method and type of solder used it is quite common in older xbox models. If you xbox is still under warrenty then that is the best solution. Otherwise there are many do it yourself fixes on the web. It will require resoldering of the graphix chip which has a large heat sink on top of it. I have an old xbox with this same problem, I have installed the xclamp modification and then some and still fight with this error. Search of xbox xclamp modification for more info on this problem.
Jan 28, 2011 | Microsoft Xbox 360 Console
System just stops playing and 2 red lights come on
Your system is overheating.
Check whether the fans are running. If not, that's the problem, check whether they are jammed or faulty (replace, check power).
If they are running, then take the 360 apart completely, take the motherboard out of the case. Remove the heatsink (the lower one). Use rubbing alcohol to remove residual heatpaste from the heatsink bottom and from the GPU (the thing that the heatsink was covering).
Reapply (thinly but completelty) GOOD thermal paste (e.g. Artic Silver nr 5). Replace the heatsink by either using the xclamp or use washers and bolts/nuts (google for x-clamp replacement) while you're at it.
Or take it to someone who can do this for you :) (I'm in the Netherlands, but otherwise I'd be happy to help you out (www.allsystemsgo.nl).
Jun 16, 2010 | Microsoft Xbox 360 Console
Xbox 360 Okay so I am beyond frusturated the
My device had a different issue related heat sink of fan but I got it fixed by Repair Guide They have covered many topics, You may come across many small issues.You can try this
Feb 08, 2010 | Microsoft Xbox 360 Console
Keep getting same thing over and over??
u r going 2 need 2 open it up take the xclamps off so u can get at the CPU and the GPU chips , u will need silicon gel 4 both chips , 1 red light is just the same as 3 red lights its due 2 over heating of both these chips, i had the same problom and after i put the gel on the chips it works fine now, go 2 u tube 4 a video on how 2 take the xclamps off.
Jan 13, 2010 | Microsoft Xbox 360 Console
2 RED LIGHTS
Here is a website I used when my 360 went haywire. It helped me out, maybe it will help you or at least lead you toward the right direction.
http://forums.xbox-scene.com/index.php?showtopic=484726
Aug 03, 2009 | Microsoft Xbox 360™ Premium White Console
No picture on my xbox
the best thing to do is send it back if you have warrenty .if not have you heard of xclamp fix for the 3 red lights that works aswell try searching youtube and ebay for the xclamp bolts
Jul 07, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Xbox 360
2 red lights is a over heating issue. As for fixing, if you don't want to take apart the 360 you will have to send it back to microsoft. If you're okay with taking it apart, replace the thermal paste on the CPU and GPU with Arctic Silver, and then comes the tricky part. The small black screws that are on the bottom of the frame take some fine tuning, usually you leave them fairly loose or not even put them back in at all, only once have I come acrossed where I had to bolt them down as tight as I could get them. You may want to leave the case off until you have finished finding the proper configuration.
Sep 12, 2008 | Microsoft Xbox 360 Console
My xbox flashed a red light, and the screen goes black
I went with the eraser fix and it worked like a charm. Can anybody explain why using erasers changes things and makes the 360 work without the 3 red lights flashing? Just Curious!
May 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
98 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
