Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Doesnt cool. i dont know where the thermostat wiring center is to check if that is the problem. it has digital reading
  • 572 Answers
Check for compressor operations
Posted on Feb 07, 2010
How can I verify my thermostat is good?
u can just take the digital board out of it all together and wire the compressor up so it starts up by its self. if it is a problem with the cap when u try and start it the compressor will be getting voltage are u getting voltage? do u know what type of thermostat it is? is it giving u a reading of what the temp inside is?
Mar 25, 2014 | GE (ZDWR240PBS) Wine Cooler
My 2003 Chrysler Sebring is overheating. A mechanic friend of mine is trying to teach me how to work on cars, and we redid the head gasket and ran into many issues, and this problem is our final barrier...
The ECM doesn't read the temps. it only takes the readings from the sensors and tries to adjust within given parameters. You has a coolant sensor on the car you have a temp sensor on the car. Check the wiring, make sure you didn't plug the wrong wire to the wrong sensor. Check to make sure everything is actually plugged in and getting power. It's definitely either bad wiring or a bad temp sensor.
Oct 25, 2013 | 2004 Chrysler Sebring
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
Frig stops cooling. freezer on bottom. frig is running just not cooling. made in 2008. we clean it let it set for 24 hr it cools again. is there a defrost heater that we can turn on, to solve this problem.
Hi, this model i believe has a calrod heater, and those usually dont go bad very often, its more than likely a bad defrost thermostat or control board, the thermostat is located in the freezer behind the back panel on the evaporator, the control board if it has one is going to be up in the control panel by the the thermostat, if it doesnt have a control board it will have a timer, I would change the timer and the thermostat in that case. It is also possible you have a bad heater which is also located in the freezer behind the back panel, under the evaporator, If you know how to use a meter you check this heater with an ohm meter. Let me know if you need further assistance.
Sean
Mar 26, 2011 | Whirlpool Refrigerators
Ac doesnt come on. thermostat doesnt come on a oesnt have power
check main power. is it a package unit or split system? is it a digital t-stat. if so, does it have a display? check batteries, could just be a fuse
Apr 09, 2010 | Honeywell Electronic Programmable...
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Old thermostat wiring doesnt match up with new thermostat
Look at the instuction booklet (or on the T-stat board) for a switch for the reversing valve.
Some systems reversing valves are in cooling mode when energised, some are in cooling mode when NOT energised.
You are looking for the switch (Usually very tiny, or a different jumper setting) that will change the position of the reversing valve when calling for heat/AC.
This is not a switch like the typical "ON OFF AUTO, HEAT COOL EMG HT switches. It will be on the board itself or the back of the T-stat.
Dec 06, 2008 | Honeywell Electronic Programmable...
What's the deal? Wont shut off or respond to thermostat. . .
Red= power........White=heat.............Green=fan.................(grey)-(yellow)=cool .....these are the connectons. Disconnect these wires from the thermostat and know that red/power is the only wire that send power to the thermostat, and the rest sends it back to the unit to call for whatever,, red--to . white for heat... red to green for fan .... &red to grey for cool! OK! Turn all your power on, and use a jumper wire from red / green for fan and see if the fan comes on! Then move the jumper wire from red to green , to red / to white for heat and the fan , wait for 3 minutes before removing and going to the next step. Then red /to grey for cool and check if the outside comes on. Either you have a wire touching past the insulations and making a connection, a bad thermostat ,oe excessive wire lead touching the next connection.Thank you very much!
Nov 05, 2008 | Intertherm Heating & Cooling
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
