HI- I've seen a similar problem described, where the motor on a Maytag (combo washer/dryer) works, but needs a tug on the belt to get started. You mentioned that it sounded like the motor was shot. I'm just trying to be more certain before ordering up a new motor and replacing it. I got the machine to run thru a full cylce (having to give it several tugs throughout). HOWEVER, when the timer is at the very end, just before the motor's gentle hum ceases and it's officially off, smoke starts coming from the motor! Is it definitely the motor at fault here? Or could it be that the timer or sensors are sending it signals when it shouldn't? (I don't know if that quite makes sense). I'd love a little definitive analysis on this issue! Thanx so much, Dave
  • reachdak Feb 07, 2010
    Thanx, jyackle5,
    Do you feel, tho, that the problem is specifically, the motor? I've read that when replacing the motor, is is advised to replace both belts as well. So, if I'm going to invest in all those parts, I'd like to be pretty confident that that will solve my problem.
    Does is sound to you like there could be any problem with the timer or anything else as well?
    The odd thing is that the washer was working just fine when I dismantled the dryer above to replace a part ( the housing for the filter). Then upon turning the dryer on to test it, the smoke started coming up from below.
    I know the wiring wasn't changed in any way. Does anything come to mind about what may have happened?
    thanx,
    Dave
    thanx. I'll let you know how it turns out!
  • 8,197 Answers
Yes if you motor smoke at the end then yes your motor needs to be replaced. I would replace before you use again. That is a fire hazard.
Posted on Feb 06, 2010
  • Jyackle5
    Jyackle5 Feb 07, 2010
    From wht you have added.
    Sence you have it apart I would change the belts also.
    As for the timmer I do not think that is a problem. It would be a problem if it was not working all the time.
    There is nothing else that comes to ming with what can be wrong. If you put it back together right then you will be fine. Just replace the motor and belts.
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Hi, I just purchased an older style washer dryer combo. When loaded (with as little as two towels) it doesn't agitate or spin. Belt is fine. Drum starts to turn but can't make it up the hill. Any sugg
Your motor may be having trouble starting due to a bad capacitor or start winding in the motor. Ideally you want to use a multimeter to test resistance of the start winding.
Jul 31, 2013 | Washing Machines
My son has a Maytag stackable washer and dryer. The dryer will not tumble. Could it be a belt and if so how hard is it to fix yourself?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Maytag Dryers
Hi, i´ve been using a maytag dryer for 5 years. Yesterday when I tried to use it, the start button didn´t work... nothing happened when I push the start button. I checked electricity, but it...
heatman101
Oct 19, 2010 | Maytag Dryers
Maytag stack unit washer dryer error 7E washer works dryer wont do any thing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 24, 2010 | Maytag Dryers
The dryer on my maytag stacked combo lse7804ace the motor works but the dryer doesnt spin. Broken belt?
You will need to either re-install the belt or replace it. I would assume that it's broken because it's not that common for it to just run off the pulleys.
Oct 19, 2009 | Maytag LSE7806A Top Load Stacked...
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Hello,my name is David ,I have a Maytag washer maytag lsg7806aae
can you tell if the motor is turning,if so it could be your idler pulley and youve lost belt tension,otherwise it could be your motor start capacitor if motor spins freely with power and belt off
Sep 01, 2009 | Dryers
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Maytag lse7800acw
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Jan 13, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
