Question about GE Dishwashers
After cycle is complete and dishwasher shuts down, water seems to leak into dishwasher
  • 572 Answers
If u dont have an air gap the water from sink syphons in ur dishwasher. if u have an air gap maybe ur valve is faulty
Posted on Feb 06, 2010
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
Bosch dishwasher SHU66C02UC
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Jul 22, 2008 | Bosch SGV56A13 Built-in Dishwasher
How do I over ride power button, force shut down
The dishwasher has detected a leak, and is trying to drain all the water out of the dishwasher. The problem is that the water has leaked into the base of the dishwasher, and the drain pump doesn't drain water from there! You dishwasher probably has a 1 or 2 lights on (or flashing), which also, when decoded, would indicate a leak. Basically, you have to pull the dishwasher out and sop up and dry up all the water in the base. That will stop the drain pump from running, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose. Good luck! If this sounds like more work that you feel qualified to do, I recommend you call a professional repairman. For Samsung dishwashers, I recommend calling Sears.
Aug 26, 2014 | Samsung DW80F600 24" Black Built-In...
Out dishes come ot with a film that looks like soap. It seems like it does not rense completely. Thanks,
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Please post back if more information is required.
Daniel
Aug 21, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a Hotpoint Super Plus dishwasher 7820. It worked well for a long time. Towards the end of the cycle it leaks a lot of water from the underside of the door, so it seems. I have fitted a new door...
The door seal has to be in a proper position completely around the door (including the bottom area of the door). If not, it will leak. Also, there are two black corner baffles/seals (located in each front corner inside the tub area) that may also be the culprit. Additionally, there may be an issue with the float switch assembly that shuts off the water supply prior to the wash cycle. If the float switch assembly is allowing an extra amount of water in the tub, it will cause a leak.
Feb 26, 2010 | Hotpoint Dishwashers
It starts then stops. never completes the cycle. it shuts down. it will drain thats it.
If the cycle didnt complete check the following:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place doing one function continuously the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Sep 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
