Question about Welding Tools
Wire wont feed through it jams
Whats the best way to clean out the welder hose bc i cant get the wire to feed through its jammed or soomethingit will only feed about a couple inchs of wire then stops completely
  • 12,061 Answers
Sounds like your "Feed Controller" is faulty. Or the sensor.
Posted on Feb 07, 2010
My wire feed wont work propley
Check the small wheels that drive the wire are correct for the wire you are using and clean/ properly tensioned.. Cheap "hobby" welders have poor drive arrangements and the hose to gun plastic lining wears through. All causing poor feed. If its a good brand google a user manual.
Aug 14, 2016 | Welding Tools
Tip
Wire feed jammed on welder
You're trying to thread a new reel of wire on your welder, but it keeps getting hung up.
Happens sometimes when you're pushing on a rope. This may help you see it through.
You will need lineman pliers or some other type of heavy duty grippers
  • Release the drive wheels
  • Pull it back out from the spool side by manually turning the reel
  • Snip the end of the wire if it is at all bent.
  • Lay the feed hose out in a fairly straight line
  • Re-engage the drive wheels
  • Pull the feed trigger until the wire either makes it through or stalls
  • If it stalls, release the trigger and use the pliers to work the wire back and forth until the it clears the snag area. Try not to twist or kink the wire
  • Repeat the procedure until the wire has made it all the way through
That's about it
Best regards
Mike
on Jun 04, 2010 | Welding Tools
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
My welder suddenly stopped feeding wire and gas when i push the trigger. i'm assuming that either there is a problem with the trigger signal or the duty cycle was exceeded. If the duty cycle was...
I found a manual that has a lot of information in it.These welders only have a duty cycle of 30% so that means you can only run them 3 minutes out of 10.They have thermo switches that shut them down before they get to hot.The house breaker needs to be around 50 amps at least I have a 125 buzz box and a wire feed and that's what I use.I would check the circuit breaker in the house to see if its tripped.I turn my mig on the side so that the shavings from the wire pushing wheels don't get pushed into the liner and clog the wire and make it jam.Well hope this helps.Thank You for choosing FixYa.com and good luck!
http://www.hobartwelders.com/service/owners-manuals/
May 15, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Lincoln weld pak 100. The wire jams in the hose. it is feeding pro... the wire jams in the hose. it is feeding properly but the wire gets hung up a foot or 2 before the nozzle. More the wire jams in the...
In your other post I had mentioned installing a Teflon liner that would help with the wire.It narrows the gap in the hose and gives it a more easier feed.
Jan 10, 2010 | Saws
Wire not feeding correctly
Check for the correct tip size first. Too small or too large portal will jam wire in the tip. Check for correct wire speed for amperage used, too fast or too slow coupled with the distance from work piece will do the same. Check for wire condition, if the wire is rusted......you do the math. Check polarity......DECEP vs. DECEN for the type of materials welded. ARE YOU USING AN ANTI-SPATTER AGENT? Build-up of spatter can cause early arc. Lastly, is the wire tension too high? The wire should not feed at all even with the motor drive unit running if the wire has fused to the tip, that leads to a kinking of the wire behind the feeder (spool side).......check also the backlash adjustment to keep the wire from spinning off the spool under load. Too tight will cause the outer cladding of the wire to strip off the core wire which will cause the core to adhere to the tip.
Jan 05, 2010 | Firepower Flux Core Wire Feed Welder 88...
Will not feed wire when trigger is pulled. feed
1. Wire jammed
2. Out of wire
3. Not enough tension
4. Wire liner worn
5. Wire disconnected internally
6. Contact tip clogged
Aug 06, 2009 | Welding Tools
Wire won't feed into hose adapter.
You will have to adjust the tension at the feed wheels, also make sure the spool is not too tight, I had the same trouble with the 180 model, just a bit of fine adjustment
Aug 02, 2009 | Hobart Handler 140 Mig Welder
NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Apr 10, 2009 | Welding Tools
Welding Tools Logo
217 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
