Question about Dell PowerEdge 700 Server
Unable to boot from cd
I am unable to boot from CD to be able to reinstall the OS
Machine goes automatically to the RAID and boots the currently installed OS.
I already installed the latest BIOS with no change in the results.
    Problem Solver:
  • 11 Answers
Change the boot sequence first priority to cd and next to harsddisk.....
Posted on Feb 16, 2010
Windows does not start automaticly it gives options like safe modeboot with the last knows config and start windows automaticly. When I click on any option the machine goes off and when I try to repair...
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert Xp cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 18, 2010 | Computers & Internet
I have dell 4600 pe serveri want to install Server2003 os i have configured raid 1 on the machine every thing is fine but! on boot process it display message no Boot Device Found Press F1 to continue F2...
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Jul 01, 2010 | Dell PowerEdge 4600 Server
Boot.ini file problem
Please reinstall windows os in your pc , but retaining all your files and setting while installing process goes on. You should select leave current files and setting in the installation process to retain your valuable files.
Feb 12, 2010 | Dell Inspiron 530 Desktop Computer
GA-8I915G duo boot priorties , need CD First NOT RAID!!!
disable all drives from booting in bios except CD. After first reboot when reinstalling enable the other drives. This should work without a problem
Jan 19, 2010 | Computers & Internet
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Sep 07, 2009 | Dell PowerEdge 2600 Server
Locked G3
Time to completely erase the hard drive.Start up from your install CD with latest version that will run on this Blue and White.. Don't expect to save any existing files. Just do a complete erase and reinstall via disk utilitly and then your os disc... let me know how it goes..
Mar 14, 2009 | Apple Power Macintosh G3 (Blue and White)...
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Can not boot
Check the CD for damage and clean the cd drive with a lens cleaner. This sounds like a software or cd drive issue not a hard drive issue. It could also be raid drivers that need to be reinstalled. But this is less likely.
Sep 13, 2007 | Computers & Internet
Dell PowerEdge 700 Server Logo
815 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
