Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Whirlpool ADP5966 - flash code 12 and fault on display F6
Flash code 12 and fault on display F6
when running a programme fills with water, there is a strange whiring and clicking inside the pump and the heater. heater isnt shorted out (read 25ohms) there is mains either side (which says to me it isnt being switched on , i.e. switched to earth).
anyone shed any light on this ?
Chech drain pump
Posted on Mar 03, 2008
My machine starts and then flashes F12 and stops working what's wrong please?
Deborah,
if your machine is a Hotpoint/Indesit the F-12 error code is a communication error between the main pcb and the display pcb. No simple fix im afraid, a new main pcb is required.
you will need to contact the manufacturer.
Aug 19, 2016 | Whirlpool Washing Machines
How can I correct a recurrent F6 error?
you may have got a water inlet valve that is faulty, return and exchange.
press the helpful button
Feb 04, 2016 | Whirlpool Dishwashers
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
F6 code and red star symbol
f6 error is the waterflow to machine if your water is ok then check your flow meter its a bib plastic part on the side of your dishwasher it a common problem with whirlpool
Feb 01, 2014 | Whirlpool 24 in. ADP5966 Free-standing...
My whirlpool adp5966 is stuck on fault code f7 and i dont havee the manual!
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work.
The following worked for me:
Remove the filter on the floor of the machine, including the metal grill.
Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it.
My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
May 09, 2008 | Dishwashers
F7 fault
I had the same problem. Indicator flashing. F7 displayed. Nothing seems to work. The following worked for me: Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a programme). this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filter's clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine. F7 in whirlpoolese may mean "Clean my filter now or you can wash your own bloody dishes"
Apr 14, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Feb 21, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966
just choose another programme setting and hold the start button in for a few seconds. this should solve the problem
Dec 24, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Nov 16, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
944 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
