Question about Canon PowerShot SX100 IS Digital Camera
My cannon A570 was working fine. Then all of a sudden it would turn on and turn off right away so I changed the batteries. This did not help. The lens was opening very slowly. Then it wouldn't open again. I received a change battery message which was odd but changed the batteries again. (they were pretty hot) Once I changed them it worked again for a second but now it wont turn on. Any suggestions?
  • 1257 Answers
SOURCE: Lens cover only partially opens
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
Posted on Jul 10, 2008
  • 285 Answers
SOURCE: canon a570 battery fail - with any and all new batteries
Hmmm...... there might be a time battery that needs replacing. Look fore something like CR1220 or time battery. Pry it open and replace it with a battery of the same size.
Posted on Jan 30, 2009
SOURCE: Powershot S5 IS wont turn on
was it ever left in the sun?
Posted on Mar 14, 2009
t00nz
  • 4738 Answers
SOURCE: My canon powershot a570 is not powering on despite changing the batteries. Any suggestions?
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 23, 2009
  • 3 Answers
SOURCE: Canon A580 lens stuck open with lens error
Put in real Kodak batteries. pull out the lens a bit. same just happened to mine
Posted on Jun 27, 2009
ReplacementdoorA570cannonpowershot
Hi
If you are looking for a replacement door for the battery compartment of you camera i would suggest the following.
Simply search for a Faulty Cannon power shot A570. Faulty ones sell for a lot cheaper. Then just replace the doors of both camera. Ebay is a good place to look.
Jul 21, 2013 | Cameras
How do I use the self timer on the cannon powershot A570 IS?
From the menu, select the Drive Mode (third item from the top) then one of the self-timer options.
Nov 21, 2010 | Canon PowerShot A570 IS Digital Camera
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Batery goes down very fast
you need to buy original cannon battery, there's no other solution regarding that matter..
Mar 28, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon powershot A570 is will not turn on, have tried new batteries and still will not work
get a new camera...this camera sucks...wasted tonnes of money on new rechargables...just didn't last long for more than 50 shots each battery change...after that, it couldn't turn on after connecting to DC input....just get a new camera and chunk this away....
Jul 03, 2009 | Canon PowerShot A570 IS Digital Camera
Cannon A590 "Change the batteries" after replacing new batteries
Off-the-shelf NiMH rechargeable batteries, and the special lithium nonrechargeablebatteries sold as esepcially good for camera use, don't have enough voltage output for this camera. Try using regular alkaline batteries or the rechargeables sold by the manufacturer.
Mar 27, 2009 | Canon PowerShot A570 IS Digital Camera
Canon a570 battery fail - with any and all new batteries
Jan 05, 2009 | Canon PowerShot A570 IS Digital Camera
Camera says new batteries are dead
I found out how to fix it. (STEP 1.) Take out all of the batteries. (STEP 2.) Hold down the power button for 30 seconds. (STEP 3.) Put the batteries back in and you should be all set.
Dec 28, 2008 | Canon PowerShot A570 IS Digital Camera
For some reason the camera won't turn on. We just bought it a few months ago, and it was working.Suddenly it stopped. We even changed the batteries. What happened? It is a Canaon Powershot A570 IS
This can be anything from a bad battery contact, to something that went defective on the circuit board. Just double check that you are inserting the batteries properly if it takes AA types.
You would be best off to call Canon's tech suport and arrange for warrenty service.
Jerry G.
Apr 19, 2008 | Cameras
Canon PowerShot SX100 IS Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
