Question about Dishwashers
We have whirpool dishwasher Mod DU1055XTS02 and the control panel the black part is coming apart. What kind of glue needs to be used to repair it. Thanks
  • 572 Answers
Any glue. plastic glue.
Posted on Feb 06, 2010
Whirlpool Quiet Plus Dishwasher
If your dishwasher doesn't work at all, check these:'
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Oct 27, 2008 | Dishwashers
Where can I get a black door panel for my Hotpoint Dishwasher.Mod # HDA 200x-68ba. I think the part number is EAP 26126
Go to www.applianceart.com they have all kinds of colors and panel options. they have designs, colors, textures, holiday ones, and even stainless steel. www.applianceart.com
Aug 26, 2010 | Hotpoint 24 in. HDA3400G Built-in...
My Whirpool Quiet Partner III has no power. I
Hello there: It doesn't work at all If your dishwasher doesn't work at all, check these: Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool controls are locked so I can not use any other button to turn it on...any way to unlock it? already tried opening/closing door several times.
you sure its lock ?
it might be the fuse in the control panel burn..
what is your model # i tell you the part number and hoe to fix it...
Jan 23, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirpool dishwasher
Ours does the same thing. I have been suspicious that it is the melting plastic stuff used in the dishwasher tabs that the wife uses.
Let me know if you use that same tab to wash you dishes.
We dont have any problem with the stuff getting on dishes (and we use all white diner type dishes.).
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Dacor mdw24s
the issue is the controller board seems not to be insulated and then the glue from the connector that holds the power to the board comes apart from the heat of the wash.  I removed the board, resoldered it (power cables are the black ones) and it seems to work.  Plus I added insurlation to the front of the door (simple .5" insulation from Lowes) and now my board works a lot better.  Thus far no more CL.
Aug 04, 2008 | Dishwashers
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
Owen Barnes
