Question about Proform Crosswalk 500 Treadmill
Belt on my treadmill is slipping & jerky,
It's a Nordic Track C2000
SOURCE: i have a proform treadmill that slips as soon as i
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Posted on Sep 09, 2009
SOURCE: Nordic Track Treadmill Viewpoint 2800 : The belt
It needs to be adjusted as shown in your owners manual.
There are two allen screws located at the back end of the treadmill. That's where you adjust it. 3 - 4 inches of slack midpoint is just right
Posted on Nov 23, 2009
  • 3 Answers
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Posted on Feb 20, 2010
  • 11 Answers
SOURCE: My Nordic Track C2000 walking belt keeps slipping
Could be out of adjustment. Belts will stretch with time and there should be a mechanism for keeping the tension, but if you've exceeded the limit, it might slip.
Posted on Feb 24, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
How to instructions on replacing nordictrack c2000 walking belt
check youtube.com and search Nordic Track belt. There will likely be a video from Nordic Track to show you how to do it.
Jul 31, 2014 | Nordic Track Exercise & Fitness
How to replace walking belt on a nordictrac c2000
Follow this video is not the same model but almost all treadmills have the same way to replace the walking belt:
http://www.howtoreplacemywalkingbelt.com/
Jul 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
Nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Oct 23, 2011 | Nordic Track Exercise & Fitness
My Nordic Track A 2050 is slipping. At first I noticed it slip from time to time in my 45 minute workout, but at the end, it was like I was on ice. I love this treadmill, is there a way to fix it?
Have you tried adjusting the rear roller bolts with an allen wrench? That usually works for me.
Unfortunately now I have a slipping problem that tightening the belt via the roller bolts doesn't fix. In fact, I feel as if the belt is too tight as it only lifts about 2" instead of the recommended 3-4". Hope we get some other ideas here!
Dec 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
When I plug in my C2000, it lights up for one second then shuts off.
Is the red panic switch located correctly? This is the small square red plastic tab that magnetically attaches to the console in the lower middle beneath the iFit slot. The C2000 does not work unless it is connected as a safety precaution as you are supposed to attach the other end to your person and so you stop the device if the slip etc.
Nov 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
My Nordic Track C2000 walking belt keeps slipping while I stand on it, what are some possible solutions?
Feb 23, 2010 | Exercise & Fitness
Feb 05, 2010 | NordicTrack Exercise & Fitness
Our belt is slipping on our nordic track c1900 treadmill, how do i fix it?
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Sep 17, 2009 | Nordic Track NordicTrack Treadmill, A2550
Proform Crosswalk 500 Treadmill Logo
196 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
