Question about Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range
I have a MER5765RAW. The bottom electric element stopped working. I don't see any fusibles or breaker.
  • 572 Answers
Check to see if element looks cracked. take it off and to a continuity check
Posted on Feb 06, 2010
ARE FUSES AND RELAYS THE CAUSE OF MY HEADLIGHTS NOT WORKING?
Given the limited information, the short answer is YES. A fusible link or the car's version of a circuit breaker is responsible for the headlights and other accessories. There may be other things not working that you haven't identified yet. Since it's extremely rare for both headlights to cease working at the same time, either 1 stopped a little earlier and it went unnoticed, or there's an electrical problem (likely a fusible link) that is the cause. It's been my experience that automobile electrical specialists are much better than dealerships or regular service stations at diagnosing these problems. They don't come cheap but it's usually $$$ well spent. Best of luck with your headlight problem.
Greg
Nov 04, 2011 | 2003 Chevrolet Monte Carlo
I have an Turbochef NGC oven that keeps tripping the breaker. There are no faults but seems to only trip the breaker when the sausage setting is entered.
BEFORE WORKING ON OVEN MAKE SURE YOU TURN IT OFF AND DISCHARGE CAPACITOR.IF YOU DON'T KNOW THEN STOP HERE AND CALL TECHNICIAN.
If you know how to use multimeter than check the resistance of Convenctional heater and the IR element.
CC heater .....not sure how many ohms
IR should be 14 ohms
If both are in specification then replace breaker(thermostat in the oven).
Usually if breaker trips 4-5 times then its good to replace it.
reply me if you need more help
and don't forget to vote me.
Aug 10, 2011 | TurboChef TORNADO Electric Oven
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
Model/Serial#: MER5765RAW/15589899JR--exit sabbath mode
Try flipping off the breaker at the breaker box for about 10 minutes and see if it will reset itself. If you continue to have problems with it, just give us a call and we will troubleshoot this problem for you.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7AM until 7PM CST and we will be happy to get you cooking again.
We hope this helps and we look forward to working with you again.
Ella
Jan 06, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Maytag oven will not heat past 225 degrees.
Check to see if it is programmed for Celsius instead of Fahrenheit. eric
Jul 02, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
FEF366DC Electric Kitchen Range Problem
osunds as if yo perhaps blown the circuit breaker, got to the fuse box and try resettting the breaker first , if not labeled its going to be a "double breaker" youll need to fully turn it off and then reset to on position
Jan 25, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range Logo
120 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
