Question about Kitchen Ranges
How do you replace the keypad on a Kitchenaid range??
  • 3,247 Answers
Might be of some help if you provide the model number of your range.
Posted on Feb 06, 2010
  • Sam Feb 07, 2010
    I think there is some mistake here. I am still trying to find the model no. of the Kitchenaid range so that I can try to find a soluton.
    I have not solved th problem yet.
Error code F2E4 On model KESC307 Kitchenaid Superba?
Tech sheet doesn't say much says noise interference at keypad says press cancel button and remove electronic noise interference if code returns replace key pad assembly not a common code if you chose to replace the keypad make sure it comes with instructions have changed two has to be programmed
Feb 14, 2015 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid range ProLine series kesv908 and ykesv908 Oven desplay comes up with err button stuck F2EO
Hi barbsofarell,
The error F2 - E0 code means a shorted keypad (also called touch pad). Please follow the steps below to correct the problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | KitchenAid Kitchen Ranges
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Mar 27, 2011 | KitchenAid KGRT607 Gas Kitchen Range
Have error message F2EO,oven not working
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
Nov 21, 2010 | KitchenAid KESC307 Electric Kitchen Range
Stuck key
Replace the keypad. You can check the ribbon going from the keypad to the esc board for kinks, but in my
experience the keypad is just bad. Depending on the age you may be better off with a new stove. Those
keypads aren't cheap.
Oct 20, 2010 | KitchenAid KESC300 Electric Kitchen Range
Display reads EO -F2- stove top works, oven will not
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Error F2E5 on Kichenaid oven
F2 - E1 Keypad cable unplugged1. Check keypad connector for firm connection (keypad connects to control board).
Apr 01, 2010 | KitchenAid KERC507 Electric Kitchen Range
F2 E0 - KITCHENAID ELECTRIC RANGE
F2-E0 Shorted Keypad Replace Keypad
Note if keypad is replaced and same code ,
replace control.
Feb 16, 2010 | KitchenAid KESA907PSS Electric Kitchen...
Oven preoblem kitchenaid ykers807sp "err f2e1 stuck/shorted key " showing
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Jul 17, 2009 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
