Question about Acer n50 Pocket PC
How to setup wireless on acer n50 pocket pc
I cannot work out how to connect to internet via the wlan wireless conection. can anyone help. thanx
I need help to connect via the wlan wireless connection plese help thanks
Posted on Mar 25, 2008
Can someone tell me How to setup wireless on acer n50 pocket pc
Posted on Sep 01, 2008
    Problem Solver:
  • 5 Answers
The manual is not very helpful and people may still be looking for an answer. This is the procedure
Go to start, settings, click on connections tab. tap on network cards.
Select internet from the drop down list, then select Samsung WLAN CF
Card and press OK on top right.
leave the dot in "use server assigned IP address", click ok.
You will get a message to say that the next time adaptor is used it will
have new settings. Click ok. You can now exit those pages. Go right out, shut down wlan.
Now bottom right of the main screen to the left of the bluetooth icon is
like a little box with a small person? and red cross. tap it and go to turn wlan ON. You
should see your SSID and be prompted for a key. If not, go to wlan utility
instead. or go to the beacon/lighthouse top right of start screen and tap that. Father Christmas
Posted on Aug 13, 2010
4 Suggested Answers
mstr2kx
  • 102 Answers
SOURCE: Acer N50
Hi mach1 Your PDA is fine, it only needs two things. A Firmware update that could be obtained from Acer's website. And your battery needs to be replaced. If it was up to me, I prefer that you visit a support center, then get all your problems fixed. Goodluck
Posted on May 18, 2007
SOURCE: acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
Posted on Dec 17, 2008
fossildude
  • 832 Answers
SOURCE: Internet dont work
hi thanks for using fixya!!
You need to contact your Network Service Provider regarding the GPRS settings that can be set to your phone, and on this services, your provider will charge you depends on their terms and conditions.
Hope it helps, if you need further assistance, let me know!
Pls rate me positively! Thanks!
Posted on Apr 18, 2009
I have hp pocket pc,but problem is that i can not connect with internet.plssss replay me how to connect with internet
What model is your ipaq? Does it has WIFI? If it does then:
Make sure that your WLAN is ON
Go to:
Start, IPAQ Wireless, and turn ON WLAN then:
Go to:
1) Start,Settings, connections tab, connections again, Advance tab, Network Card and you should see your Wireless networks.
From there it will vary depending if your wireless device has security on. WEP, etc.
Hope this helps.
Aug 16, 2010 | Microsoft Windows Mobile 2003 for Pocket...
Pocket pc says it is connected to internet, if I try to go to a site an internet explorer message comes up the page you are looking for can not be found, if pocket pc is hooked up to another computer if...
Most probably, you are experiencing the mentioned symptoms because the wireless setting for your PDA are not set up correctly.
Have a look at the following link:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
and scroll to the section: "Using the Wireless LAN (H5550 only)". If you are not using the WLAN utility and are connecting to the internet using a different device, try having a look at the sections: "Connecting to the Internet" and "Using Bluetooth"
Hope it helps.
Aug 06, 2010 | HP iPAQ H5550 Pocket PC
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Acer n30 wlan card
Aug 26, 2008 | Acer n30 Pocket PC
I am trying to get a wireless connection on my acer aspire. i have spent 6 hours over the last 3 days on calls to my broadband service provider and they seem to think that my wlan is disconnected and have...
check all conections. make sure software is istalled properly. try the wireless conection wizard in internet options.
does ur wireless dongle pick up other wlans
Jun 25, 2008 | Computers & Internet
Wireless connection not working Acer Travelmate 2410
Delete your existing wireless connection and then run the wireless connection setup wizard.That would work up .this is a fast and saves your time without dilly-dallying anywhere.
Feb 04, 2008 | Acer TravelMate 2300 Notebook
Wireless conections
Turn the unit on, Click on start. go to ipaq wireless. turn on the WLAN it must be green to be on. Tap on it once if it orange to turn it green. Then it will detect any wireless Wlans around there you go.
Dec 23, 2007 | HP iPAQ H4355 Pocket PC
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Acer n50 Pocket PC Logo
968 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
