No you guys are **** wads... I hope you all die in abject pain preferrably in a fire... not liek a low little burny fire... but like an INSANELY hot bon fire... so that a distinct fatty burning and popping noise can be heard. You kno wwhat I'm talking about when you cook fatty pork over an open fire... if not I can attach an associated audio fire to place this all into context... Have a nice day. Yours in faith and love, -Andrew
techman
  • 3130 Answers
SOURCE: Sony KVTS27 audio noise and pops
your problem is a stand-up printed curcuit pcb it has several mof those small surface mounted caps that always goes bad and the # on the part is SBX1981or SBX1981-51p its part # is 874213400 its about 11 to 15 bucks . Dont try to repair the part as the pcb is eaten up from the caps leaking all over it. Good Luck
Posted on May 06, 2006
SOURCE: Realtek HD driver problem
thanks
Posted on Jan 01, 2008
SOURCE: audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Posted on Jan 15, 2008
dauphine
  • 207 Answers
SOURCE: burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Posted on Apr 09, 2008
goalie39
  • 469 Answers
SOURCE: my grandson saw a bike at walmart. it had a little
http://cgi.ebay.com/BICYCLE-HANDLE-BAR-GRIP-N-GROWL-NOISE-MAKER---MINT-WOW_W0QQitemZ120350469307QQcmdZViewItem
The link above is for a twist grip style, my son had one of these until it wore out.
These shoud be available at most major bicycle shops.
Hope this is of some help.
Ed
Posted on Apr 30, 2009
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
My rainbow 1650- was working fine then all of a sudden it powered down and had a burning smelt a little electrical, but also like something else. Then I hit power switch andi unplugged The unit. I took...
It might have been the wad passing through but with a burning electrical smell it should be checked out by qualified technician. Burning electrical smell means it may catch on fire
Sep 23, 2013 | Vacuums
Hot tub motor loud
Get it repaired ASAP.. IT'S the bearings ! these little pumps are a pain to work on but if caught in time can be rebuilt. $75-150.00 SEARCH YOUR AREA FOR your local pool pump motor repair guy
Jay the pool pump repair guy in sunny longwood Florida 32750
Also this is one of the hardest motors to work on, (called a threw bolt) let a pro do it.
Dec 29, 2012 | Pool & Spa
Bike stalls out when gets hot.done oil change ,coil, sparkplug,intake to carb boot, air filter, im outta ideas, cause it goes fine just dies when it heats up,but after it cools fires right up again enough...
i just got a buell 2001 blast had been stored for a while had little bit of bad gas so i cleand the carb out still would die so i askd a tech at harley he said 99% positive that it was the slow jet its a 3.95 part inside the carb take out the old slow jet and replace it with a new 1 cuz u cant clean it out good enough cuz its little pin holes i put new 1 in and it runs like a champ now the guy said no need to rebuild carb just new jet and ull probly be all good my bike would start idle for a min then die and the tech said if that jet is plugd bike wont hold a idle its the jet screw deep inside the carb pull the carb take the bowl off the bottem then ull see the jets hope it helps you out
Aug 18, 2011 | 2001 Buell Blast
WN111v2 Netgear USB Wireless N Adapter is going at such an insanely low speed..... it's supposed to be a 300Mbps adapter, but i'm having trouble going over 54 mbps in the windows indicator. I...
when you did your speed test was the unit of measurement in Mega Bytes or Mega bits ?
Why I am asking this is because 54 mega bits a second has to be divided by 8 to get what mega bytes units are ? As a bytes is 8 bits of data.
I have been caught out by this myself with speed tests .
I suspect this might be the case with your situation .
Sep 04, 2017 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Hi, hope you can help me. I have a 2009 yz 250 I race here in Hawaii and we do alot of tight trail riding.My problem is when my bike heats up to the point of it boiling over it just dies out but when I...
If you are talking about really slow trail riding in low gears,the bike may get hot.If you are still moving along the tracks and getting airflow over the rad, it shouldn't get hot.If you go really slow it might get hot but not if you are still moving at at least 10mph.The fuel/air mix maybe set a little rich.That warms things up.Do not let the bike sit and idle.That will make it overheat.If you stop,turn it off.No exceptions.Hope this helps.:)Mahalo(Does this mean thank you?)Me from Oz
Jan 06, 2010 | Yamaha YZ 250 Motorcycles
Diesel rodeo dies and lack power when cold and in winter
Try changing the fuel filter and get the glow plugs checked or replaced .Diesel goes a little waxey in colder weather making it harder to go through the filter .
Hope this helps.
Jul 23, 2009 | 1988 Isuzu Trooper 2 Door
Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
May 12, 2009 | Vivitar 285HV Flash
The mower is a cub cadet it usually runs fine until warm and will die start idling up and down and then die every now and then pop like back firing.it will start right back if you lift the choke i changed...
I had the same problem , found out it was the coil was getting hot. I replaced the coil which was not hard , remove 2 screws an unhook 2 wires. You have to get the coil from a dealer , in my area anyway. Hope this helped.
Apr 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a fiat spider 1981. Starts fine but when motor gets pretty heated it spurts spatters acts like it is choking for fuel or air or something. It dies and in about five minutes it starts again. Any...
When my 79 fiat spider did this it turned out to be the ignition module located in the distributor. My fiat would die when it got hot. Let it sit for a little while it would fire right back up. Have you tried that yet? Here is a parts supplier for FIATs if you do not already know about these guys:
http://www.international-auto.com/
Mar 02, 2009 | Fiat Pininfarina Cars & Trucks
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
