Question about Frigidaire Affinity ATF7000E Front Load Washer
Door lock buzzing
I'm having problems with the door lock. I'm having to slam the door shut very hard and the door lock still buzzes. Just bought this washer brand new last month.
  • 1,531 Answers
Sounds as if your door lock is broken and needs to be replaced.
Posted on Feb 06, 2010
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Door on Frigidaire front load washer loose
have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
2003 expedition
Behind your door panel and behind that canopy cover which is plastic. All the way to the door locking striker or door latch which fastens the door closed when shutting. By and below this is a cylinder which has a steel rod running from it to your door lock indicator which you see that goes up and down when you lock your car. This electronic lock has failed and seems to be stuck is why the buzzing sound is . Replace this your problems will be over. Please rate my solution it is how i get my achievements Thanks
Apr 10, 2012 | Cars & Trucks
My front passenger side door lock make a buzzing noise everytime I lock it. All the doors lock but it makes that buzzing sound as it locks. What is the problem?
It's called a door lock actuator, and ours was on the driver side, buzzing each time the doors locked. Very annoying. We ordered it online, it was part #4717961AB from a Mopar company. Wasn't very easy to replace ourselves, but do-able if you have at least an hour and two people working on it. Cost us $60 plus shipping._418.jpg
Dec 28, 2010 | 2002 Chrysler Sebring
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
My fromt loader buzzes while running.
Try some WD40 on the mechanism of the lock, not on door. And open & close a few times, while disconnected from the mains.
May 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
296 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
