Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG Tromm Dryer is leaving black marks on my clothes
  • 156 Answers
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Posted on Feb 25, 2008
johnychel
  • 796 Answers
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
  • 22 Answers
SOURCE: My washer is marking LE.What does that mean?
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Posted on Aug 01, 2009
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
I have a LG TROMM DLG5988S, it doesn't warm up my clothes
your element is defective or a thermal fuse is open, possibly the hi-limit switch is defective
Oct 18, 2009 | LG DLG5988 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Black marks on clothes
Use your tub clean feature and throw in some affresh www.affresh.com to see it that will clean out your unit. Check your button trap to see if anything is there. Insure you use HE branded detergent and cut back detergent and on your fabric softener, only tablespoon or 2 will do. Only use enough to satisfy your requirements and you will save money in the process.
With your roller balls, you can check it out, use a phillips screwdriver. On the baffle itself there is one screw and then it slide out. Maybe something is caught there.
I can't think of anything else that might be causing it. One thing, do you notice it on the clothes when you take them from the washer, or from the dryer. If it is when they are dry, check the felt inside your dryer, they have been known to get black and transfer onto the clothes. Sometimes they put too much grease in there or it could be from the rollers in the dryer as well.
Sgt 48
May 19, 2008 | LG WM2688HWM TROMM SteamWasher
Lg tromm front load dryer dlg5988w
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
160 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
