Question about Kitchen Ranges
Igniter is clicking and won't stop
We have a Maytag gas rangetop and the igniter started clicking and won't stop. It has been clicking for at least the last 3 hours. Is there a danger with this? Is there a way to stop it.
Thank you.
  • 572 Answers
U have to replace the spark module if only one is sparking. if all spark the check polarity on plug
Posted on Feb 06, 2010
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
HELLO I HAVE MAYTAG GEMINI GAS RANGE IT IS MAKING CLICKING SOUND WANT CAN I DO
The concern is tha the clicking sound is from the igniter for the gas.
It is correct at least in my stove that at the time you are turning on the flame that for a few seconds the stove generates a clicking sound which is actually arcing from a high voltage supply. Once the flame is lit the advancement of the flame control is to a higher flame position -OFF that of the start, is when the clicking should stop. There is no reason to leave the igniter on for a long time. If it does stay on all the time then that is a service issue that should be addressed. igniter devices can be expensive to replace- they are NOT continuous operational parts.
Aug 23, 2012 | Maytag Kitchen Ranges
Maytag gemini electric ignition won't shut off
Your valve switches are defective. Sometime they will do that if you recently had a boil over and they have got wet. Try turning the breaker off for 24 hours to see if the fixes the problem.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Maytag Gemini 30" Self-Cleaning...
Sparker turned on by itself and would not stop
Hi rlimaye1,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Maytag MGC5430BDS Gas Cooktop
Igniters on my Maytag gas cooktop do not spark
u nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
Jun 27, 2009 | Maytag MGC5536 Gas Cooktop
Wolf Sealed Rangetop Stopped Igniting
Do any of the burners click? If not, you may need a new spark module. If only one isn't clicking you may need a new ignition switch that is just behind the knob. I have also seen wires get pinched,stopping the flow of electricity. It may also be a computer board issue which is rare. Sooo you really need to call for service.
May 28, 2009 | Wolf Manufacturing Gas Kitchen Range
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Kitchen Ranges Logo
215 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
