Question about Garden
I hav a dayton pressure washer with a 10hp tecumseh engine, model hm100. when im using it and let off of the trigger.the engine does not rev down like it should when it meets its pressure limit. what can i do to make it work right?
  • 43,501 Answers
I have seen this here all day, so I'm going to let you know what my first thought is.
It seems so simple that I figure you probably tried it, but I'll give it to you anyway...
There should be a pressure sensing switch that will kick the motor back. I think that the unit is not building enough pressure to activate the switch. I may be getting worn and not be able to build the amount pf pressure that it once did. The switch may have went bad... anyway try adjucting the switch to a lower pressure and see if that works... or check out the switch and if it still will not activate then the switch needs to be replaced.
Heatman101
Posted on Feb 08, 2010
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
Engine revs up down while in idle
check carby for missing spring or damage
Mar 19, 2014 | Garden
Carb needs rebuilt and I do not know the part # for this engine, Tecumseh HM100 159370P-B
Should be a metal tag somewhere on the tiller that gives all the information, Will give Model #. type and serial #. Your parts dealer can I dentify the carburetor from those nos.
Feb 20, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How to remove coleman powermate 5000 generator from Tecumseh 8 HP motor for engine model number hm100.
4 bolts to the engine then altenator will just pull off may need a puller to get it moving
Feb 01, 2010 | Coleman Powermate Powermate 5000W...
Pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Jul 21, 2009 | Briggs & Stratton Garden
Tecumseh HM100 piston replacement
standard size rings & im sure it the torque should be 40 in pounds
Jun 08, 2009 | Garden
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
HM100 tecumseh
Did you buy the starter separate? If it came with the engine, it should already be hooked up. If you have to wire it yourself, there is a PDF file online (Tecumseh Technician's Handbook) that tells how to wire it up.
Dec 31, 2008 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
