Question about Mitsubishi VS-5043 50" Rear Projection Television
I am attempting to repair a convergence issue on a Mitsubishi VS-5043 50? rear projection TV. I have the electronic base completely removed from the cabinet except for 2 issues at this point. Firstly, I have one long wire, which I have yet to disconnect. It is a red wire that?s kind like a spark plug wire where it?s a heavier wire and has a rubber boot on it where it plugs into the side of another component. It has a white tag on it marked ?FBT?. I am unsure as to what kind of pressure to apply to remove this without breaking it. Any idea if a twist is needed or simply a pull? Or both? It does not seem to want to twist.. Secondly, the board that is turned on its side, attached to the main pcb thru an edge connector and is right on front of the convergence IC?s. This board seems to be inserted into 2 small plastic connectors. I see a small nub on either connector but am unsure as to pull the nub out or push it in towards the component board to release it?? I assume it should come completely free from the remaining main pcb assy? Many THANKS in advance!
  • Kevin Barnes Feb 07, 2010
    The pics are here:
    http://img708.imageshack.us/i/p2070015s....
    http://img21.imageshack.us/i/p2070012f.j...
    The first is the transformer wire. OK...I am an electronic technician, tho TVs are not my forte. Should I be discharging a high voltage to ground here somewhere to alleviate my being killed by this thing when I remove the PCB from the chassis? It has been unplugged for the last day or two and all other wires are disconnected. What lethal charges will still exist on this pcb once I have it in-hand? Can you give me any safety tips for this job? I greatly appreciate any heads-up you can give me. I know to stay away from large capacitors and thick wires, but the rest is unknown to me.
    The second pic is not a great shot but shows the "latch" on the board at the main pcb where it attaches...just to the right of the small blue capacitor It resides in front of the convergence ICs... There is a small nub (behind the capacitor in the pic) that I assume assists in the removal of this board, but not sure how to loosen it without damaging anything.
    Thanks for the time and effort to help!
    I now have the board out of the chassis and on a tabletop. It appears that the board standing up in front of the convergence IC's is also soldered into the main pcb. I assume that means I will just have to de-solder the convergence IC's to release the IC's and heat-sink as a single unit. Still need to know about shock hazards though...thanks...
  • 4,889 Answers
FBT means flyback transformer also called high voltage transformer. This is the most dangerous part to deal with and you have to be extremely careful. You see the suction cups at the end of the thick wires? You have to squeeze and pull them to disconnect the wires.
I did not understand your second question though. Can you get me an image(Upload a highres pic to imageshack.us and get me the link) so that I can help you remove it?
Sai.
Posted on Feb 07, 2010
  • eagle338
    eagle338 Feb 07, 2010
    Discharge the flyback and you should be fine. Discharging it also s-ucks the voltages held on the capacitors. As long as you stay away from the large capacitors(Like you said) you should be fine.
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Colors out of alignment
If you have background in electronics, you can do it. The difficult part here is on how to access those convergence amp(convergence circuit output IC). By replacing those 2 IC and some resistors sometimes, adjust the convergence and your done. Good Luck
Mar 05, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Convergence issue on a Mitsubishi VS-5043 50'' rear projection TV
Tunesmind, were you able to pull out that board, if so, did you pull or push on the nubs on the connector
Feb 06, 2010 | Televison & Video
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Screen has double image in red
This is a convergence problem that is either poor solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Update this if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Mar 24, 2009 | Mitsubishi VS-50501 50" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Convergence problem & some...
I don't know where you live but Dave at Sy Electronics (480-917-8889) in Arizona knows how to fix Mitsubishi Tv's. If you have been told by your local TV repail place that parts are no longer available don't believe them. Call every repair place in town until you find a comptent and knowledgeable tech. That is what I did. Roger
May 30, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
