Question about MSI K8T Neo2-F Motherboard
MSI K8TNeo2-F v2.0
Recently my computer would not bootup and when I used the reset button it would keep starting windows then resetting itself,some times it will go to startup options.
please help.
Lan treiber Fehlt mir
Posted on Jul 13, 2008
    President:
  • 2,351 Answers
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Posted on Feb 21, 2008
  • Mike Peluso
    Mike Peluso Feb 26, 2008
    scorcher63, you did not post back. Did you want to add more information?
How fo i Factory reset my msi gx630 laptop
If it is Windows 8 and mean resetting the operating system you can use the built in refresh feature of Windows 8. Go to control panel > open Recovery. At the bottom there is a link which reads 'If you are experiencing problems with your PC, you can refresh it in PC settings'. Click on it to open PC Settings recovery options. You can use the topmost option 'Refresh your PC without affecting your files' to keep folders like My Documents intact. Or 'Remove everything and reinstall Windows', this will delete everything and do a full reinstall. It should use the recovery drive available on your laptop to restore to factory defaults.
Apr 28, 2016 | MSI Computers & Internet
My msi A6200 laptop goes thru the installed things again again. Won't let me go to recovery or reset... help. What keys do I press
Hit the F8 key during the bootup and if menu pops up select "last known good bootup" and hit enter - see what happens.
Or use the recovery disks that came with your unit or that you were supposed to make. If no disks you may be able to purchase from MSI. Otherwise you will have to do a clean install of the OS from regular install disks.
Dec 03, 2015 | MSI Computers & Internet
Reset tablet c
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the powericon1.png off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if theLED lighticon1.png flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
[Answer supplied by Aris C on Fixya.com]
Jan 22, 2014 | MSI Computers & Internet
The screen just keeps saying that windows didnt start succesfully and it gives me 5 options to start none of which works please help??
Welcome to Fixya!!!
If all the the options in the Advance option wont work. 1.Removed your battery, ac adapter and drain you power button for 5 to 10 seconds. 2. Used only ac adapter and turn on the laptop keep on tapping f8 3. Tried any option again. first choice would be last known good configuration. then try safemode 4.If you are successful in going to safemode, try to do system restore. If it fails to load all oftions, and you dont have any important files -Try to reboot pc and hit f3 to reset the computer to factory setting. it will open a prompt to do a complete restore. If f3 does not work- the recovery partition is already corrupted. -You need to call MSI tech support to get a recovery disc from MSI -You need to resinstall the Operating System.
Mar 06, 2011 | MSI Wind U100-280US Netbook
Msi netbook reset
Not that complicated:
1. Enter to BIOS (when PC bootup try to hit F2 or F10 or DEL, it will show which is correct but you may just hit all of them)
in BIOS you will find tab and option "reset to default"
2. Then about the HDD, just install new system on it (XP, Vista, Win7, whatever you wish)
Cheers,
Mike
Leave rate if I helped you, thanks!!
May 08, 2010 | Intel Motherboard
Forgot password and username
Yes there is.
1. First turn the power off the router and press the "reset" button.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
MSI K8T Neo2-F Motherboard Logo
164 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
