Question about Logitech QuickCam Pro 5000 Webcam
QuickCam Pro 5000 P/N 861205 is not compatible with Windows 7
Are there any fixes for this problem, or do I have to be a WebCam
  • 1 more comment
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    Can you give me a little more information as to what your problem is with your web cam? I can probably help if you provide me the problem. Bud
  • gcsltd
    gcsltd May 11, 2010
    pls clarify!
  • Hans Kabalt
    Hans Kabalt Apr 14, 2014
    i found a soluion for getting logitech quickcam pro 5000 working for windows 7.Just press the litle black knob that is on the top of youre cam and putt youre instalation cd in youre pc.What happens next is that the cam automaticly starts asking toy to follow the program.i tried this yesterdayevening and now my gam is working.
You need to download the drivers (v11.1 for another OS you can reach. (http://www.nodevice.com/driver/QuickCam_Pro_5000/get65050.html) On the second computer, start the instalation, but do not proceed, just leave it open.
On Vista, go to User/[YOurname]/Appdata/Local/Temp/Logitech-????
on XP find the same folder in teporary files (I'm not sure where to look for it) and copy the Drivers folder to your WIN 7 machine.
Run the setup.exe
Posted on May 18, 2010
  • Logit3kZorro May 18, 2010
    For PN 861205
    1) You need to download the drivers (v11.1 for another OS you can reach. http://www.nodevice.com/driver/QuickCam_...
    2) On the second computer, start the instalation, but do not proceed, just leave it open.
    3) On Vista, go to User/[YOurname]/Appdata/Local/Temp/Logitech-????
    On XP find the same folder in teporary files (I'm not sure where to look for it)
    4) Copy the Drivers folder to your WIN 7 machine.
    5) Run the setup.exe located in Drivers/bin in compatibility mode with WIN Vista SP2 (RightClick->Properties->CompatibilityMode)
    6) Restart your computer and plug in your camera. It should find the drivers automaticaly.
    Note: The 64/32 bit versions of drivers should match.
    Bye
    Logit3kZorro
    President:
  • 8,637 Answers
Not sure what your problem is but will give you this to try and if that's not your problem let me know and I will probably be able to help you.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Mar 10, 2010
  • Weldon Dube'
    Weldon Dube' May 18, 2010
    You will need to download the latest camera driver so it will work with Windows 7.
    Copy the Microsoft Web site and paste it in your web browser address bar and hit ENTER.
    http://www.microsoft.com/hardware/downlo...
    then select the necessary items as listed below, such as
    1. Select type of product. (Web cam)
    2. Select your product (camera model).
    3. Select your operating system. (XP, Vista etc.)
    4. Select your operating system langusge. (United States English)
    A. Skype Setup:
    http://www.skype.com/intl/en-gb/download...
    B. Yahoo Setup:
    Microphone
    Speaker
    Camera
    Notes:
3 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: my logitech quickcam pro 4000 and windows 7 are
Copy this site and paste it in your web browser address bar and hit ENTER.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
From the images, select the webcam and then download your cameras driver.
Then to install and use it on the Web, do this.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
On the VIM sign-in window, click on Edit.
Microphone
Speaker
Camera
conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
SOURCE: is not compatible with windows 7
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Posted on Dec 06, 2010
Logitech QuickCam Pro for Notebook freeze on Win7 platform
Try using it in Compatibility Mode
Right click on the Logitech webcam desktop icon
Select Properties and Compatibility tab
Check the box for CM
Select the OS
Apply OK
May 18, 2010 | Logitech QuickCam Pro Webcam
Cant get computer to recognize web cam
The Quickcam Pro 9000 is only compatible with PC, Windows XP SP2 at least.
If your virtual PC runs Windows 7, there is a known issue running it in Windows 7. If this is the case, I suggest to contact the manufacturer.
There is one made for MAC though; QUICKCAM vision PRO. Manufacturer's part number is 960-000254.
Hope this helps! Please don't forget to rate or vote. All the best!
May 07, 2010 | Logitech QuickCam Pro 9000 Web Cam
I have windows7 and a quickCam model number
go to link
choose windows 7 and 32 or 64
and download
Mar 07, 2010 | Logitech QuickCam Pro 5000 Webcam
Need driver for 7 driver i have is for vista and xp
http://www.logitech.com/index.cfm/support_downloads/downloads/webcams/&cl=us,en
Feb 15, 2010 | Logitech QuickCam Pro 5000 Webcam
I lost my webcam cd installer
how can i download cd installer of my logitech webcam quick cam*8.3.2( window) and quick cam *8.0.1( mac os*)
Aug 22, 2008 | Logitech QuickCam Pro 4000 Webcam
Windows vista home premiun
Please click on the link mentioned below to download the drivers:
Windows Vista Multilingual 32-bit
* Title: QuickCam v11.1.0.2030
* Software Version: 11.1.0.2030
* Post Date: 8/7/2007
* Platform: Windows Vista
* File Size: Approximate download size is 30.7 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110.exe
Windows Vista Multilingual 64-bit
* File Size: Approximate download size is 36.3 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110_x64.exe
Also visit this website:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-QuickCam-Pro-4000.shtml
Thanks
Aug 22, 2008 | Logitech QuickCam Messenger Web Camera
Also visit this website for other Windows driver:
Thanks
Aug 21, 2008 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Pro 5000 Webcam Logo
2,415 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
