Question about Car Audio & Video
I installed headlight/turn signal switch on 1987 toyota supra how do i correctly install the spring and ball assemby on this unit to have proper function of my high/low head beam ?
  • william cook Feb 07, 2010
    The link you gave me comes up with a manual in foreign language.
    I installed headlight/turn signal switch on 1987 toyota supra how do i correctly install the spring and ball assemby on this unit to have proper use of my high/low beams?
  • 3,741 Answers
Headlights, there is a requirement for switching between a high beam and a low beam, and two principal systems are used for this purpose.
One of these utilized a sealed beam type lamp in which two light sources are provided in conjunction with a reflecting mirror. When one of these light sources is operated, the low beam is generated, and when the other light source is operated or both light sources are operated at the same time, the high beam is generated. In this type lamp the beams are switched by switching the light sources.
In the other system, one light source is utilized with a reflecting mirror. The beam is switched by rotating the reflecting mirror or the light source, itself, upward and downward.
This invention relates to the latter system, the problems of which are discussed below.
In headlights which switch between low beam and high beam, the downward attitude of the reflecting mirror when the low beam is lit must be controlled with great accuracy to avoid blinding oncoming traffic. Previously, a vertical aiming bolt and a surrounding coil spring have been used to control the attitude of the reflecting mirror in the vertical direction. This bolt acts as a stopper, which controls the downward attitude position of the reflecting mirror. In addition, the spring is designed to permit the rotation of the reflecting mirror to allow upward rotation. Moreover, an actuator is used to make the reflecting mirror rotate upward and downward. Hitherto, solenoid systems, compressed gas systems, or motor drive systems have been used as actuators.
the ball and socket assembly has particular alignment settings.if not familiar with this then its advisable to get it done by local car garage technician, This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 07, 2010
  • 17,970 Answers
I think that this MANUAL can helped like a first step. I'm keeping in a new search for more specific details.
Hope this help.
No dash lights
Check the obvious first. Is the fuse ok? When you turn on the headlights do all the outside lights work correctly? check the fuse, if its ok check the headlight switch.
Jun 03, 2012 | 1985 Toyota Celica Supra
1986.5 toyota supra turn signal does not flash when in the detent only flash when partially hold down, replace flasher no help
do thr break lights work? sometimes people put the blinker bulbs in reversed and cause the low element to flash which will not be seen over the high element..oh and congrats on having the beast.im an evo owner
Jun 03, 2010 | 1987 Toyota Supra
How do i install a t70 turbo to a 1987 toyota supra turbo 7mgte 3.0
you will need an additional turbo manifold. I have the correct one its for sale right now on eaby. The ct26 turbo manifold does not allow for proper mounting. I can include directions with the manifold
Dec 03, 2009 | 1987 Toyota Supra
1987 Supra Non-Turbo has tem gauge issue. Gauge needle jumps;
Its eather the gauge or sending unit. On a single wire unit,if you ground the wire ,the gauge will max out.This means the unit is bad. I hope this helps.
Sep 04, 2009 | 1987 Toyota Supra
I have a 1987 toyota supra and it isnt getting any spark
poss bad earth, check ecu supply when then cranking. if not you need an oscilliscope to see what is up with signal on crank sensor, some vehicles power cable is so close the noise from it wipes the signal same as a bad starter it interfers with the signal, (noise is the magnetic fields)
May 18, 2009 | 1987 Toyota Supra
1987 supra left headlight blowing fuse
there is a really good chance that you have a bad power or ground wire. based on the age of the vehicle i would say that it is most likely corroded but it could also be cut or burned
Feb 24, 2009 | 1987 Toyota Supra
What is correct tire pressure for 1987 supra
look on the metal part of the inside door frame on either the driver or pasenger side. it will tell you there. should be around 32psi if stock tires
Jan 19, 2009 | 1987 Toyota Supra
1987 toyota supra.
hmm. . . . go to tuner shops. . . for sure if they dont have one they can order 1 form japan. . . it maybe an aftermarket clutch but why not. . . they last longer. . . 8)
Oct 22, 2008 | 1987 Toyota Supra
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
