Question about Brother Sewing Machines
F2 error on brother sewing machine..what does it mean? wont do anything but beep
On mine this means the button for reverse is stuck. Just wiggle the button a bit and it will pop out again. It can get pushed in at a slight angle and catch a bit, but nothing is broken... I don't know if this is the only thing F2 means, but it is one thing!
Posted on Mar 26, 2010
  • instakate8 Oct 24, 2010
    YES!!!!!! THANK YOU!!!!! Mine was a stuck in needle threader button but I would've never even looked at those buttons if not for your post! F-2 means the buttons are stuck in!!! And now my machine works!!! Saved me from $300 thank you soooooo much for posting this!!!! :o)
  • mary_horton1
    mary_horton1 Oct 10, 2012
    Thanks!!! happened to me before too... This time I forgot that's what was wrong lol. Thanks
Good afternoon, My Brother sewing mach. has a error of f7 what does this mean. The model is Cs80
According to http://www.sewingmachinesplus.com/brother-sewing-machine-error-code-f7.php
the meaning and answers are as follows...
Q: What does F7 error message mean?
A: Speed VR disconnected
Q: How to fix F7 error message?
A: Unplug the sewing machine and reconnect any loose wires on the SSVR PCB assembly and the main PCB assembly. If the wiring connections are okay, replace the SSVR PCB assembly. If the problem persists, replace the main PCB assembly.
Jan 10, 2017 | Brother Sewing Machines
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
I get an E2 error on my Brother CP7500 and the button lever is all the way up
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operation
    One beep is sounded.
  • If an incorrect operation is performed
    Two or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangled
    The sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew.
reference: http://support.brother.com/g/b/faqend.aspx?c=us_ot&lang=en&prod=hf_es2000teus&faqid=faqh00000059_000
user guide:
http://download.brother.com/welcome/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
quick reference guide:
http://download.brother.com/welcome/doch000566/bc21es20ce50qg02enfresdeitnlru.pdf
Dec 15, 2014 | Brother CP7500 Sewing Machine
What is the Brother Pacesetter NX-200 F4 machine error, and how do I fix it?
You will receive F4 error message, when there is a problem within the unit, internal circuit board.
Your Brother Sewing machine need to be service.
Good Luck.
Oct 19, 2011 | Brother Sewing Machines
My sewing machine screen says F02 and wont let me do anything
Go to brother-usa.com and download the manual. It does mention how to reset the machine for the error message to go away. If this does not work, call Brother at 1-877-276-8437
Sep 08, 2010 | Brother CS-8150 Computerized Sewing...
Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Jul 22, 2009 | Brother SE-270D Computerized Sewing...
Error F2
This error means you have the buttonhole lever down while not sewing the buttonhole stitch. The lever is located next to the presser foot, it's white. Just push it back up. If this isn't what's going on, then your machine thinks that's what's going on and it needs to be reprogrammed.
for future reference, check the manual. If you don't have yours anymore go to retrevo.com and search brothe cs100t and register for free and download the manual
Oct 27, 2008 | Brother CS-100-T Computerized Sewing...
Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Aug 18, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
1,046 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
