Convergence issue on a Mitsubishi VS-5043 50'' rear projection TV
I am attempting to repair a convergence issue on a Mitsubishi VS-5043 50” rear projection TV. I have the electronic base completely removed from the cabinet except for 2 issues at this point. Firstly, I have one long wire, which I have yet to disconnect. It is a red wire that’s kind like a spark plug wire where it’s a heavier wire and has a rubber boot on it where it plugs into the side of another component. It has a white tag on it marked “FBT”. I am unsure as to what kind of pressure to apply to remove this without breaking it. Any idea if a twist is needed or simply a pull? Or both? It does not seem to want to twist.. Secondly, the board that is turned on its side, attached to the main pcb thru an edge connector and is right on front of the convergence IC’s. This board seems to be inserted into 2 small plastic connectors. I see a small nub on either connector but am unsure as to pull the nub out or push it in towards the component board to release it…? I assume it should come completely free from the remaining main pcb assy? Many THANKS in advance!
Tunesmind, were you able to pull out that board, if so, did you pull or push on the nubs on the connector
Posted on Feb 19, 2010
VS-60719 60 in. Rear Projection Television: Blue Convergence is off, can't solve by using the ...
When the convergence problems happen.100% ur tv convergence board the 2 STK convergence ICS,and some or all it resistors are dead.These parts must be change,to be solved convergence problerms.Tries Websites like TvrepairWorld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Only if u know how to do soldering,and have soldering equipments and solders.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Mitsubishi VS-60719 60" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
The colors aren't matching up I have green semi
Yoy have convergence issue with tv,try the magic focus/touch focus or manual adjustment in the menu under convergence, if can't be adjusted then your convergence ckt is the problem,you will need a tv tech to repair it.
Mar 19, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
Nov 17, 2009 | Mitsubishi VS-55601 55" Rear Projection...
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
Nov 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Color convergence
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Can you help me please
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
