Question about GE Refrigerators
MY GE MODEL GBS22HCRWW REFREGERATOR IS NOT GETTING COLD; BUT THE LOWER FREEZER UNIT IS WHAT IS THE LIKELY CAUSE?
  • 749 Answers
SOURCE: Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Posted on Nov 19, 2007
kachbibi1
  • 979 Answers
SOURCE: Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Posted on Jan 24, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
Posted on May 20, 2009
tborn6
  • 700 Answers
SOURCE: GE Model GSH22JFTA Top of Fridg and Freezer not cold
check the door gaskets for air leakage
Posted on May 21, 2009
  • 13677 Answers
SOURCE: I have a Haier model HTE14WAAWW refrig. with top
check the fan in freezer sounds like it is stuck [iced up ] or needs to b lubed at the back of freezer will see fan feel if fan is blowing or just humming
Posted on Sep 24, 2009
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
We have a GETFX27ILB 26.6cu ft. refregerator an the one side isn't getting below 60 degrees.
Could you again give us the model and manufacturer for the refridgerator.
Thanks
Proton
Jul 23, 2008 | GE Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
The freezer section of our ge refregerator keeps making a loud buzzing noise and causing our food to frost. I have already lowered the temp.; however, it doesn't seem to help.
This would indicate moisture is getting into the freezer and not getting out.
Run a manual test of the defrost cycle.
Aug 16, 2009 | GE Freezers
I have a LG refregerator.Two doors GR 726 RW Model 32RE1202 Serial 302KR00062 Water dripping from the freezer chamber to the chamber below. What could be the problem? The setting in the freezer...
the water is from defrosting coil in rear of freezer and there is a drain pan under coil to make water drain to pan under unit where it evaporates from compressor heat.possible cause for water not going where it is supposed to is drain is clogged with foreign matter or frozen shut.I would suggest checking door gasket seals if you are getting this often moisture is getting in and causing lots of frost for unit to deal with and could lead to a repetitive problem.
Apr 19, 2009 | Refrigerators
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
