Question about Brother MFC-5460CN All-In-One InkJet Printer
My printer has stopped printing the red ink properly. I installed a new Magenta cartridge and cleaned the printer several times, but it still won't print red correctly. The other colors work fine. Can you help?
  • Brother Master
  • 13,433 Answers
Hello I suspect that the red cartridge nozzle in the printerhead is somewhat blocked with dried link. printerhead is the unit that carries the cartridges around the printer. on the bottom of the printerhead there is a small hole where the ink is released from, this is most likely blocked and it would need to be cleaned. I would suggest that you use a product similar to this (Magic Bullet) http://www.specialistinks.com/unblock-printer-heads.php here is a video of the product
Posted on Feb 06, 2010
  • Ekse Feb 06, 2010
    Sorry, seems like I have to re-write the solution so it comes out correctly with the video included..
    cleaned.
    http://www.specialistinks.com/unblock-pr...
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Epson stylus c88 red ink prints yellow
print a check of the nozzles, and check what colour (magenta) is not working. If the cleaning part does not help, perhaps you should put a new cartridge in, or clean again.
Feb 17, 2015 | Epson Stylus Office Equipment & Supplies
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
Hi I am not getting any Red from my printer
It's possible magenta ink to be finished, or the print head is dirty and it has dry ink on it. You must clean it with hot water. You must use the printer from time to time to avoid to dry the ink cartridge or print head.
Mar 08, 2011 | Canon i455 InkJet Photo Printer
New ink not printing
If the printer is recognising the cartridge it is probably installed correctly. When you choose Print, check that the magenta image is red and showing a level. If you have run the purge and head cleaning options I would say you have a dud cartridge
Feb 19, 2010 | Epson Stylus C86 InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Brother MFC-5460CN All-In-One InkJet Printer Logo
119 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
