Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
Many Frigidaire
dishwashers come with the promise of being the "quietest dishwasher in
its class," according to Frigidaire. However, a quiet dishwasher doesn't
necessarily mean that the dishwasher is silent, as some noises are
normal. It can take some troubleshooting at times to determine if a
noise coming from the dishwasher is typical or if it indicates a larger
problem
Listen for the sound of water filling and draining throughout the washcycle. These sounds are normal and do not indicate an issue.
Pay attention to the drain
motor, which operates at the beginning of each cycle. This noise should
be fairly quiet and should not sound like a loud, grinding or banging
sound.
Note that the sound will change
when the wash cycle moves between the lower and middle spray arms. This
sound should be temporary and fairly quiet.
Look for hard items in the dishwasher
grinder or filter if a loud crunching, buzzing or grinding sound is
heard. The dishwasher can typically grind up these items within one or
two cycles, but the item may be lifted out and discarded to eliminate
the sound.
5
Remove the bottom rack and spray
arms from the bottom of the dishwasher if there is a loud noise coming
from the dishwasher that does not resolve itself. Look inside for the
impeller, which is round and spins. Remove any debris that may be
clogging up the impeller or pump.
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Danby customer service told me that it was built into the machine. The machine would shut off for about 15 minutes after that loud noise occurs. Then would finish the cycle after that point? Got infants, buy one of these products! LOL
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
this is a cutting blade that helps cut up bigger debri that should have been washed off the dishes, you should not be able to see it if you are not taking the cover off,, where is the cover?? you might want to lacate this,, this might be your whole problem, it could be stuck under the dryer element, or lodged in undr the blade that throws the water around,, locate this and you might have found the problem
My Dishwasher had the same loud Grinding Noise. It was a piece of a plastic fork lodged behind the macerator blade. This is at the suction to the pump just under the strainer. check this out first before you pull everything apart. You should be able to get to it by taking the lower arm off and pulling the strainer out. Hope this helps.
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
You might have something bouncing around in the wash pump inlet in front of the "chopper". Remove the lower arm and upper arm supply tube. Remove the screws then remove the screen, accumulator and inlet protector. You should see debris in front of the screen.
