Question about Kenmore Dishwashers
Plastic spoon melted on dishwasher element ? can it be cleaned? how
  • 572 Answers
Id scrap it with a knife and a fine sand paper
Posted on Feb 07, 2010
One of the thick plastic severing spoons apparently fell to bottom of washer, it has melted on to the heater part, how do I get this utensil off if the heater.
your best bet is simply to unplug it and break it off carefully then use steel wool to clean up the heating element of the remaining plastic. if need be and there is no danger of melting anything else you can use a pen torch to heat up and hard to remove plastic and wipe it away with a cotton clothe or scrap of denim some fabric that wont melt.
Sep 25, 2017 | Dishwashers
The plastic ties were left on the oven rack. One melted . How do I get the plastic off the bottom of a self cleaning oven?
Warm Method Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them. Step 1 Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2 Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
Aug 26, 2017 | Ovens
A spoon will a plastic handle melted on the circular heating element on the floor of the dishwasher. It is stuck on there, should we pry it off? Will the dishwasher still work? What do you suggest?
Hello, Thank You for using FixYa. I will be helping you today. Yes i would remove as much as you can you wont damage the heating element. Then run a cycle with heated dry and check after the cycle if you can remove the fest.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
Melted a spoon on element. What can I do to remove plastic on element
The way to remove it is you need to raise the temprature of the element to the level when the spoon melted, not so easy of a task, but nothing else will do it.
I would fire the element, and be ready with a damp terry cloth towel, and wipe the spoon free. Another way would be to use a propane torch, but you MUST protect everything around the element or you will cause more damage.
The key is that you have to acheive the same temprature that melted the spoon, and it will release and leave little, if any residue..
Feb 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
A piece of plastic spoon melted on heating element. Is there a way to clean it off.
Make sure the heating element is cool. Remove as much of the melted plastic off that you can by hand first. You can use a straight edge razor to lightly scrape it off. When you have most of the material removed, get some fine emery paper or steel wool to finish removing it. DO NOT use anything that is so abrasive that it penetrates the outer shell of the heating element. Once a hole forms and water gets inside, the element has to be replaced. I hope this helps you.
NOTE: I would not recommend using any kind of cleansers as they tend to leave residue.
Feb 08, 2010 | Dishwashers
Plastic spoon dropped onto the hearing element. does element need to be replaced?
no you dont need to do anything but remove the spoon from the heater. the heater wont be harmed and will continue to work properly.
Jan 03, 2010 | Maytag 24 in. MDB6100A Built-in Dishwasher
Plastic melted on Dishwasher heating element
youll have to run a whole cycle again and pay attention to when the heating element comes on again. Once its hot the plastic will be soft enough to remove it with a tight cotton rag. Use you oven mitts for protection. Hope this helps
Dec 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
163 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
