Question about Maytag Neptune MDG5500AW Gas Dryer
Fin inside dryer drum is loose - Maytag Neptune MDG5500AW Gas Dryer
  • 572 Answers
Unplug unit open front panel. reach in to tightned. if screws missing look on flooring of unit. they always there
Posted on Feb 06, 2010
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Fin inside dryer drum loose and rattles can it be
get to out side of drum and tighten screws
Apr 25, 2010 | Dryers
Fin on gas dryer loose.
The model number is generally inside the door or door jamb area. The top must be removed to access the drum to tighten the screws to the fin
Apr 15, 2010 | Maytag SDG4606A Gas Dryer
Fins inside drumare loose
Open the top ... held down with spring clips ... remove the front panel ... probably 2 to 4 screws ... be careful of the wires ... unplug the machine of course. Remove the drum ... but first observe the belt arrangement so you can reinstall. Tighten the 'fins'. Reverse the procedure.
You can use a pry or large screw driver to pop the top. Be careful of the finish.
Mar 21, 2010 | Dryers
Loose fin
there are two clips located between the front part in the frontpush those clips in and lift it up rest it back out of the way some of the dryers have small bolts holdind the fins on if so tighten them up and some dryers have only push in plasic clips these fins have to be replaced i certainly hope that i was able to help you and by the way close the lid, thank you.
Dec 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Hi, We have a Neptune dryer that has lost all of its 3 fins.
yes this is to me, you have to take off the door, and panel, loose bolt that holds top to front panel and you will be able to turn the drum and reinstall baffles with screws, you may need to add a flat washer if the holes have stretched.
thanks
Aug 22, 2009 | Dryers
I have an LD9334 Dryer with a noise when the drum turns. One of the fins inside has a loose screw and is hitting the top as it goes around. Does the top of the dryer come up or do I have to fix from the...
I fixed mine it by opnening up the gray vent panel in the lower right corner on the rear of the dryer. By spinning the drum, I was able to loom inside with a flashlight and see the loose screws holding the loose baffle in place. I was then able to tighten it.
Jul 02, 2009 | Maytag HYG2460AWW Gas Dryer
Loose Tumbler Fin In dryer
most maytag dryers have push type clips that hold the top to the front. look between the top and front with a light and find them about 3-4 inches from the outer edges. once you get the top up then there will be screws that hold the drum baffles to the drum. just put a new screw in them and all will be ok. no need to replace them, just use new screws.
Dec 31, 2008 | Maytag HYE3658AY Electric Dryer
Replacing the a drum "fin"
you should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Sep 20, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Is my drum loose?
General reasons for a knock are that the belt is chunking out or one of the support rollers has cracked. If you can get inside, it will be obvious. I'm assuming you did check to see if there is anything that parked itself in one of the drum fins.
Dec 24, 2007 | Kenmore 73952 Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
