My m530 printer gives me error number SC10 message stating mechanism error.
First thing to do is unplug everything and wait for twenty minutes and then plug it all back in and see if the error goes away. If it does not clear, check to see if you have a small piece of paper stuck somewhere in your printer rollers. The 5C10 error code means something stuck inside the printer (like a small piece of paper) I would also uninstall and reinstall your printers drivers, click on the link below to reinstall your drivers and software
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
http://www.justanswer.com/questions/2gorx-reference-pixma-mp830-printer-working-great-last-evening-turned
Posted on Feb 07, 2010
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
We have a Rimage Everest II S/N 06074034 model number. Requesting Transfer paper?? Problem states "Retransfer out"
Hello Spacheco763,
The serial number provided is a DLN5200. I am assuming you are using the Everest II printer with this autoloader.
I don't think the message you are saying is the full message, but I will attempt to help.
If you just changed the ribbon and are getting an error stating there still isn't any left, go into Printers and Faxes and right click on the Everest II. In the drop down menu, choose printing preferences. Click the utility tab and open the Status Monitor. Here you can reset the ribbon count and view the status of the printer and ribbons.
If it is giving you a upper or lower retransfer ribbon error, the sensors closest to the retransfer ribbon need to be cleaned.
If this does not fix your problem, it could be a possible hardware issue. The serial number you provided is not under a service contract and will be going end of service (EOS) very soon. If you would like discuss this, feel free to give our support team a call at 1-800-553-8312 (Option 2)
Dec 06, 2010 | Health & Beauty
Unable to clean cartrigde
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Jul 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-465CN printer. Need a fix for error 46.
Jul 09, 2010 | Brother MFC-465CN InkJet Printer
Phaser 8400 Error Code 07.009.42:265696
Hi carlt322:
Here is your problem.
7,009.4x: PM_FAULT_HEADTILT_PARK_ ERROR
The printhead is tilted back but not in the park arms and restrained properly. This is due
to the wiper assembly not moving up far enough for the park arms to hold it.
1. Check the printhead heater wiring.
2. Check for an obstruction or damage in the process
gearbox. Ensure the gears are correctly aligned and
homed, see page 6-8. If faulty replace the process
gearbox assembly.
3. Run the Head Maintenance Clutch test, if it fails replace
the clutch.
4. Run the Wiper Drive test. If the test fails, inspect the
maintenance drive system.
5. Replace the exit assembly.
Hope this helps
Sep 25, 2009 | Xerox Phaser 8400 Laser Printer
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
Error message "servicer reqired 10"
Please email to d_atwood@gccprinters.com for a solution. Mention the error message # 10
Feb 02, 2009 | GCC Technologies Elite 12/1200N Laser...
Error message in printer
i have dismental all side covers along with front cover of ink compartment
and i found one of the lever attached with front cover and other end
attched to the inner mechanism was disconneced.once i hooked up the lever end
with inner mechanism, my problem has been solved.now my printer works good.
thanks
girish patel
Nov 23, 2008 | Canon MF3110 All-In-One Laser Printer
32 people viewed this question
jasbo
jasbo
