Question about Dishwashers
Spray arm doesn't turn
I have a Kitchenaid KUD1230B0 dishwasher, the spay arms don't turn.
  • 177 Answers
Probably blocked spray arms. Remove each spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results and the arms don't turn as well
Posted on Feb 06, 2010
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
I removed the lower spray arm on my kitchenaid dishwasher and cant get it to screw back in. Is there a trick to doing it? The arm was the only part I removed
My lower spray is connected by a large plastic screw type piece. Do you have that part? The arm itself just sits loosely on the base and the "screw" is needed to secure it. The arm itself does not screw on. If you lost that part, I don't know how you would secure the arm.
Jul 12, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
Hello, Im trying to diagnose poor cleaning of glasses in the top rack of my Fridigaire FDB751SCB0. everything seems to work fine but while testing I noticed the upper arm isn't spinning. the lower arm...
Hello; first thing to check, which you don't mention, is which side of the glasses aren't coming clean; the outside, which would be caused by the TOP spray not working properly, or the INSIDE, which would be caused by the spray BELOW the top rack not working. The most common problem causing a spray arm not to turn, and/or poor cleaning, is debris blocking some or all of the spray holes in the arm. Best and easiest way to check them is to remove them; they usually are easily removed with a large wing nut or screw in the center. (Don't drop the screw, if you do it will ALWAYS find it's way to the hardest spot to retrieve it from in the whole dishwasher!)
Once you have the spray arm(s) out (this might be a good time to clean them all) you may notice pieces of debris partially protruding from the spray holes. DON'T pull them out; use something to push them back inside the spray arm. Pulling them out can enlarge and mis-shape the spray holes.
Dislodge any pieces inside the arm by firmly rapping it against a firm but padded object, and shake the debris out over the sink, catching it in a paper towel so it won't go down the drain. Be careful, as broken glass is often inside the spray arms, picked off the bottom of the tub and fed through the pump to the sprays.
Once you don't get any rattling inside after several "raps" on the padded object, the arm should be clean.
Cleaning these spray arms periodically is a good idea even before you have trouble.
Hope this helps, and good luck!
Alec
Jun 04, 2011 | Dishwashers
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Spray Arms won't rotate
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 16, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Diswasher
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Jun 19, 2008 | KitchenAid KUDS01FKSS Dishwasher
Dishwashers Logo
281 people viewed this question
Top Dishwashers Experts
