Question about Brother Office Equipment & Supplies
My Brother Copier MFC-8460N started popping a line on the screen that says "Replace PF1 Kit." I have no idea what that means and i have been receiving faxes and making copies in the 24 hours since this first started appearing. Can you tell me what is going on ,please? I rely on this copier/printer to forward faxes to my home office all weekend for our business so I need it working 24/7. Thank you very much. Toni Mason
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First use this method to reset the printer:
1) Turn off printer
2) Press and hold the menu button and turn on.
3) Keep holding button until you see maintenance on display.
4) Press 88. This brings up parts replacement menu.
5) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
6) Press the OK button.
7) Power off and restart printer.
If still the issue is not resolved then you can reset the message by pressing "menu" " *2864" within 2 secs. Now you are in maintenance mode. Push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. Press "stop/clear" to back out to maintenance mode screen. Press "99" to exit maint. mode. Kindly make sure to follow this in exact same way. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
What is a PF kit
This is a "Paper Feed" kit and comprises several small pieces including rollers, springs and friction separator pad. Some models have several of these and will be named "PF1 kit", "PF2 kit" etc normally one for the manual feed tray and one for the paper drawer.
If you look at the front of the paper drawer, you will see a spring loaded friction pad in the centre used to hold back all but one sheet of paper. Directly above this in the printer chassis will be a loose rubber roller assembly which grabs the sheet of paper. together, this collection of parts is called a "PF kit".
The printer memory counts the number of pages fed and will count down an estimated useful life of these parts but this is at best a "guess". When they will no longer reliably feed fresh new paper without jamming, they probably need replacing.
May 30, 2014 | Brother MFC-8460N Laser Printer
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
May 21, 2014 | Brother MFC-8460N All-In-One Printer
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
What is a PF Kit 1?
hi
PF Kit 1, is the Paper Feeding Kit, number one.
http://www.retrevo.com/support/Brother-MFC-8460N-Multifunction-Printers-manual/id/260ag208/t/2/
User manual above.Below is your service and repair manual.
www.scribd.com/.../BROTHER-MFC8460n-Series-Service-Manual
Below is what the kit is for another type of printer to give you the idea.
Oct 08, 2010 | Brother MFC-8460N All-In-One Printer
It says to replace the PF Kit 1 what is that?
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
Aug 04, 2010 | Brother MFC-8460N Laser Printer
REPLACE PF KIT1
THIS IS HOW YOU WILL RESOLVE YOUR ISSUE OF REPLACE PF KIT1 ON UR Brother MFC-8460N All-In-One Printer
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer
THIS WILL DEFINATELY RESOLVE THE ISSUE
REPLACE PF KIT1 : THIS IS IN REGARDS TO THE MAINTENACE DISPLAY THAT YOU HAVE ON YOUR PRINTER
TAKE CARE AND HAVE A NICE DAY..
Jun 22, 2010 | Brother MFC-8460N All-In-One Printer
Pf kit 1
Brothermall.com has all the Brother accessories.
Aug 20, 2009 | Brother MFC-8460N All-In-One Printer
Replace the PF KIT 1 On my MFC 8460 N
that refers to the automatic feed. in other words, your main paper cassette. the MP kit is for the manual bypass tray. if paper is feeding ok and your not having problems, you can reset the message by pressing "menu" " *2864" within 2 secs. now you are in maintenance mode. push "88" should show "parts replacement." using arrow buttons go to reset pf1 kit and press "ok" or "start" to reset. press "stop/clear" to back out to maintenance mode screen. press "99" to exit maint. mode. do not mess with any other settings in that mode as you could render your machine inop. however, you may want to reset the "fuser life" while you are in maintenance mode "88" as both of these messages are supposed to come up at 100,000 pages. chances are unless you've had fuser replaced, that message will be coming up soon also.
good luck,
razors
Mar 25, 2009 | Brother MFC-8460N All-In-One Printer
Will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
57 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
