Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
Hi there, iwant some help in duct type air condition (trane)60000 BTU .when i was gave the out door freon i recognized that the high pressure fans were off and the compressore was on ,so i turn off the air condition for seconds then turn on i found that the high pressure fans run for one minute and then turn off and the compressore still running ,so what i shell do????
  • mazen banna Feb 07, 2010
    this solution was very bad from who call him self prof. otherwise i thought that he want some dollars to solve it or he didnt know any thing about air conditions any way thanks for the advice.
    Problem Solver:
  • 16 Answers
I hate to say this but it sounds to me like you need a professional. You may hear some other advice but it's not safe for anyone to work on the outside compressor unless they really know what they're messing with. The fire and death by electrocution risk is very real.
Posted on Feb 06, 2010
I have a 2006 mitsubishi lancer. The a/c works intermittently. Works the least the hotter the day gets. The presures are 25 low side & 145 high side @ idle. What are the proper pressures ? I beleive...
Those pressures are OK and within specs. I would suspect the cooling issue lies with the air temperature control blend door actuator and or the blend door sticking in the ducting due to warpage.
Jul 26, 2017 | 2003 Mitsubishi Lancer
Air conditioning blowing warm air
if the cooling fan is not coming on the high pressure switch will shut it down check that
May 21, 2012 | 2005 Kia Spectra5
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
I have a high pressure on the high side of my air condition the high side is 340 and the low side is 60
Most likely caused by a restriction in the sealed system.
You could recover the refrigerant,replace the filter drier and pull a deep vacuum on the system,then recharge refrigerant.
Oct 31, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hi everybody i want some help , iam a technision in air conditions ,i was fix a central ac carrier and i found that everything works good the compressor and the high pressure fan and indoor fan ,but the...
if the compressor is running - the suction pressure should be 65-75 psi - if it is very low - not enough freon - if it is very high - the compressor valves could be damaged - both will cause this
Sep 19, 2009 | Heating & Cooling
System not cooling space it cooled once before?
Hi, could be compressor loosing efficiency, i think suction pressure is to high at 85, also it could be moisture in your system, did mechanic replaces filter drier on high side of system , when he replaces evap. install filter drier on liquid line, if there isn't one, also check compressor valve, you can do that by cutting or desoldering the high side from compressor, connect charging port to compressor, conect your gauge charging port, start compressor, pump up to between 150- 200 psi shut off gauge, and leave for about 1 hr. then check pressure, if pressure decreases, then your compressor valve are leaking, if it maintain same pressure, then compressor valve is o/k. you can do same on suction side, this time in vacuum, if it holds vacuum pressure, then valve is o. k, RLA(LRA) lock rotor amps, is amount of amps compressor used to start, but will drop once compressor is running, 11.6 when operating is o/k, does your evap. compatible with condensing unit?, is it right size. check also that you're using right type of freon, check condensing unit & evap labels for right type of freon, make sure they can handle same type of freon. but check compressor valve carefully, i think your comperssor could be loosing it efficiency, compressor could be your problem. good luck.good luck
Aug 07, 2009 | Goodman CLQ36AR49 Air Conditioner
Say me certain reliable brand gas air conditioning for home
Goodman, Trane, and Amana are all pretty good manufacturers of heating and air products with some of the best warranties available.
Goodman: www.goodmanmfg.com
Trane: www.trane.com
Amana: www.amana-hac.com
Hope this helps.
May 27, 2009 | House Brand Heating&Air Conditioning...
Recharge air condition
If you have solid ice build up on the "big" pipe (suction line) and very little air coming out of the vents, it's more an air flow problem; Inside fan not working, dirty coil inside (evaporator) or block filter. Open the cabinet inside and take a look there first.
This should be easy to fix; if the filter is dirty, replace it. should be done every month anyway.
If the coil is dirty, depending on access there's a 50/50 chance you can clean it you're self. If you can't you will have to call a technician who will pump all the freon in the outside unit, disconnect the coil, clean it & reinstall it, that should run you $200 to $300
You say there is a little air coming out so the fan is probably working, but if not, you will to find out why the fan is not running. That's electrical, could as easy as the thermostat is not turning the fan on to replacing the fan it self.
It is possible to have frost coming back if you are undercharge (low on freon) But the conditions have to be just right. A Journeyman mechanical carrying an EPA license working under A license contractor is the minimum you need to be able to buy freon since the 90's. that's legal of coarse.
To charge a system you also need a set of gauges and you need to know the working pressure of the system depending of the freon inside.
I think you only have a block filter or a dirty evaporator, possibly a collapse duct.
Good luck
Benge
May 27, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
Trane XE100 and I am getting an icing condition resulting in a shutdown. The fan apparently was operating but not moving any air through the room vents.When I took a panel off the fan assembly I got plenty...
Sounds like you are low on freon or you have some type of obstruction that is blocking the full flow of air across the coil.
Go for the simple thing first which is make sure you don't have something blocking the flow (like one time I found a plastic bag from the grocery store that had been sucked into the return grill and when the fan came on it would lay on the A-coil blocking the flow).
If that's not the problem then you are probably low on freon and should have the system charged.
May 18, 2009 | Heating & Cooling
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
76 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
