Question about KitchenAid Dishwashers
Clean light won't stop flashing, dishwasher won't start
  • 572 Answers
If it blinks 7 times? ur putting too cold water in unit. if its 120 degrees then check heater assembly. if its good replace it with a heater kit comes with a board
Posted on Feb 06, 2010
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Won't drain all the water, the machine stops and the red light flashes
I have just had the same problem. Dishwasher on as normal, no water going in-EEEEk, did everything the manual said to clean drain pump and non return value, no change. Then I read answer above from wcredentino and low and behold, dishwasher immediately started and no call to service man tomorrow- yay, thanks 'wcredtino' However, for me, holding both buttons at once didn't work, reset occurred when I held the on/off switch down for 5 seconds- when I held it down with the start/stop button the problem persisted.
Thankyou!
May 13, 2012 | Miele Dishwashers
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Jan 15, 2009 | Maytag 24 in. DWD1500A Built-in Dishwasher
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
98 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
