Question about Frigidaire PLMV169DC Microwave Oven
169DCD 1000 watt wont heat - Frigidaire PLMV169DC Microwave Oven
  • 572 Answers
Change ur magnetron
Posted on Feb 06, 2010
I have a brand new Avanti 1000 watt microwave. (New, out of the box). It won't heat. It makes noise like it's working, but there is no heat generated.
Take the lid off and on the side were all the components are located you could see a large transformer mounted on the bottom look at where the wires get plugged in one may not be in and hanging lose or the fuse in a white like casing come from transformer to the capacitor is blown
Oct 03, 2013 | Avanti MO902SST 1000 Watts Microwave Oven
LG Microwave not heating
there are two censors inside one high heat one low heat they can be checked with a meter if both are good its a bad magnatron and exceeds its worth
Mar 05, 2013 | GE JVM1650 1000 Watts Microwave Oven
Oven heated just minutes before and now it wont heat anything
There are three causes that would do this, the magnetron "common problem" or the high voltage capacitor and diode can be a factor, the above items work together to heat the food. The repairs can approach the price of a new one.
Mar 02, 2011 | Whirlpool GMH5184XVS 1000 Watts Microwave...
Ge spacemaker microwave works but wont heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ikki
Aug 22, 2010 | GE JVM1650 1000 Watts Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
MMV4184A 1000 Watts Microwave Oven: My microwave turns on but does not heat the food. ...
heatman101
fsjf
May 18, 2010 | Maytag MMV4184A 1000 Watts Microwave Oven
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Frigidaire PLMV169DC Microwave Oven Logo
89 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
