How can i clean the filter on my pt60lc14 panasonic hdtv
  • melissagonza Feb 07, 2010
    Husband is cleaning the filter on the front by the lamp now. We heard there are 2 filters. Do you know where the other one is? Also, will we need to reset something in the service mode to get the 'air filter needs cleaned' message to stop coming up after we have cleaned it?
    Very useful information. Thank you for your help.
  • 8,197 Answers
Please find the manual from here
http://www2.panasonic.com/consumer-electronics/support/LCD-Projection-TVs/model.PT-50LC14
says "An OSD advising “AIR FILTER CLEANING...” - Please consult your nearest dealer.
The filter is undoubtedly near the projector lamp. There has to be a lamp cooling fan that pulls air through the filter.
There is some advice on HDTVoice.com -
http://www.hdtvoice.com/voice/archive/index.php/t-3843.html
It looks like replacement instructions are available with the replacement lamp. Here is an excerpt from that web site:
From the Panasonic Operating Manual-model # PT-43LC14/PT-50LC14/PT-60LC14
TY-LA1000
Lamp unit replacement period
The Lamp is a consumable item and it’s life varies based on individual usage.
Panasonic warranties the original Lamp for a period of 1 year from the date of purchase.
• The unit will detect when the Lamp’s end of life is approaching and the following message will be displayed.
• The LAMP indicator light will be lit when the Lamp’s end of life is approaching.
THE LAMP NEEDS TO BE REPLACED,
AND THE LAMP HOUR METER NEEDS TO BE RESET.
Refer to the instructions enclosed with the lamp unit (Part No.: TY-LA1000) when replacing the lamp.
• Please wait more than one hour for lamp replacement.
[ If you need to replace the lamp more urgently ]
• The projection display has a forced cooling feature. After the POWER button is turned OFF, and sometime during about the
first minute of the normal cooling fan operation, press the VOL+ button on the projection display and the ? button on the Remote control at same time for more than 5 seconds. The cooling fan operates for about 10 minutes.
In order to access and clean/replace the filter for that chassis, you will need to follow the procedure for removing the light engine assembly. This is the reason that there is no access for a normal owner and the requirement to have it replaced professionally (personally I find it a bad design) in the owner's manual.
The procedure for disassembly should be included in your SM depending on what you have. (I work with the HTML version which has it in Section 5)
You can access the filter from the front of the unit.
Pull off the cover(it unsnaps)
remove the 4 screws in the center and remove the door (not the lamp door)
there is two sides to the filter, vacuum the top side, and use canned air to blow out the bottom side.
Personally I do not use air to blow dust around but this is an option if you choose this way.
Posted on Feb 06, 2010
  • Jyackle5
    Jyackle5 Feb 07, 2010
    The only other filter is in side the set by the lamp. Once that one is cleaned also then the onscreen reminder will go away. There is a sensor to tell it that the filter needs cleaned.
  • Jyackle5
    The in side filter
    The replacment of the filter is very difficult. Not recommended for most consumers. The filter is located under the light engine. The light engine is expensive and easily damaged. I will reccomend that you call a TV repair shop to have the filter replaced. Click here for information on resetting the lamp.
    How to reset lamp and filter on screen display.
    Be sure the power cord is plugged
    into a properly grounded wall outlet.
    Then, press the POWER button on the
    projection display or the remote control
    to turn the unit on.
    While pressing the VOL- button on
    the projection display, hold down the
    PIP or SPLIT button on the remote
    5 seconds.
Pt60lc14 model has image stain on screen
Its a LCD AND most likely means a damaged optical light engine which is the most expensive part in the set.
May 13, 2012 | Panasonic Televison & Video
Tip
Panasonic PT60LC14 Manual Download
Download Panasonic PT-60LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-60LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-60LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 27, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Tip
I hope that helps.
on Apr 27, 2010 | Televison & Video
Reset lamp for model pt60lc14
Follow the instruction on the manual.
Link for the manual is bellow.
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual[2].pdf
Jan 24, 2012 | Panasonic Televison & Video
PANASONIC PT60LC14 SHUTS OFF AMBER POWER LIGHT BLINKS 1 TIME EVERY 5 SECONDS
According to service manual when the power button flashes amber once every 5
seconds there is a problem with one of the fans not turning or up to speed or related circuit on the projection assembly.
Nov 23, 2011 | Panasonic PT-43LC14 43" Rear Projection...
How do we reset the lamp timer?
Try holding down VOL - on the TV panel and then hold SPLIT or PIP on the remote for 5 seconds. A message should appear saying it is reset. I hope this helps.
Mar 18, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt60lc14 will not turn on
DM power board have burn parts,it dead.Must know how to solders to replaced parts like capacitors puff up or replaced the whole board.Tries these Websites Shopjimmy.com or Ebay.com for refurbush board.
Jan 10, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
