Question about Nintendo DS Lite Console
Nintendo DS Lite - trying to recharge it, been plugged in most of the day. I have noticed that the red LED is flashing when the DS is connected to the mains, is this normal?
    Guru:
  • 110 Answers
This is down to a number of possabilities:
1) Give the Battery terminals a bit of a clean up by either using an alcohol solution such as white spirit or scratch them clean with a small sharp knife or scalpel.
2) Try another battery - Rather than going ahead and buying a new one first see if you can borrow one off a friend or family member for a few seconds.
3) Try a different charger - Again, rather than going ahead and buying a new one first see if you can borrow one off a friend or family member for a few seconds.
4) Your fuse/s may have blown - You need to have fairly good soldering skills as the fuse you will be replacing is tiny (1.6mm x 0.8mm). You can buy the fuse you need from ebay (do a search for ds lite fuse). Take your ds lite apart and locate the "f1" fuse (here is a link to the pic of the fuse location: http://m3wiki.com/index.php/Image:Usgcpu01fuses.jpg ). Remove the blown fuse by de soldering it and replace it with the new fuse and solder it into place, once this is done you can put your ds back together and test if the charger now works... if it does work but the ds will not switch on you will have to also replace f2 (also shown on the picture).
If you want a more detailed explaination for the replacement of the fuses do a google search for "ds lite fuse replacement2 and you should get plenty of guides show up.
Some people say just to bridge this fuse if its blown but i'm strongly against this, the fuse is there for a reason and if you bypass it more serious damage can occur and that will be far more costly and dangerous.
Hope this helps and like to say I accept no responsibility for any damage that may occur whilst using my advice.
Regards,
SOD69
Posted on Feb 07, 2010
What would cause my Nintendo DS Lite to not come on when the power button is pressed? It does the same thing when plugged in or not. The LED light flashes red, the screen blinks on, then both go off...
Hello.
Sorry to tell you but the only way to find out is by trying another charger and/or battery. So I suggest borrowing from a friend or try it in a store before buying a new battery/charger. I would let you borrow mine if you are somewhere near me. =)
Aug 12, 2011 | Nintendo DS Lite
Nintendo DS won't power-up
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Aug 19, 2009 | Nintendo DS Lite Console
Red LED light?????
Nothing, that just means it is charging, when it goes off, it is fully charged
Jun 11, 2009 | Nintendo DS Lite
When plugging power to the DS lite the led flashes orange once
I think if the orange light flashes once it means it has a full charge.
Mar 18, 2009 | Nintendo DS Lite
It can't be recharged
The DS's battery has a limit to how many times you charge it,but then again the charger's wire inside it might be disconnected.
Try to buy a new DS charger and see if its the wire,if its not then try to call nintendo to see if they might be able to replace the battery(for a fee).
Mar 06, 2009 | Nintendo DS Lite Console
Nintendo DS Flashing Lights
It just means you are low battery. Have you tried recharging it? Just turn it off and on and should you should be ok.
Jan 06, 2009 | Nintendo DS Lite Console
My ninten do flashes red
It probably needs to be charged. Connect to the charger that came with it and give it about a few hours so that it can recharge to full power.
Dec 27, 2008 | Nintendo DS Lite Console
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
99 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
