How do I adjust the speed of a Denon DP-23F? - Audio Players & Recorders
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
How do I get a schematic for a DP1100 denon turntable?
http://www.vinylengine.com/library/denon/dp-1100.shtml
Jan 19, 2015 | Denon Audio Players & Recorders
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
http://www.vinylengine.com/library/denon/dp-29f.shtml
Jun 19, 2014 | Denon DP-29F Turntable
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
Denon dp 23f
The booming could be a worn needle
Aug 21, 2013 | Audio Players & Recorders
My Denon DP-26F tonearm does not return "all" the way when finished playing a record.
Tonearm can be adjusted to travel back to its support. At the base of the tonearm is a small rubber stopper. Remove the stopper and insert a flat blade screwdriver into the slot beneath. Turn to the left and then test arm for repositioning correct. Adjust until its correct. John
Dec 27, 2012 | Denon DP-26F Turntable
Denon DP- 60L Tonearm bearings are loose, How should I adjust them..?
They can not be adjusted, Turn table has obvisily been abuse,Just buy a different one, End don,t abuse it,
Nov 02, 2012 | Denon Audio Players & Recorders
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
Platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
DP 29 turnable
I don't know what the adjustment settings are that you posted, but the speeding up could be the result of the belt in the bottom inside slipped off its spool that acts as a gear for the speeds, similar to gears on a pushbike but they are smooth spools.
Jun 09, 2007 | Denon DP-29F Turntable
214 people viewed this question
 Grubhead
Grubhead
