Question about Asrock ConRoe1333-D667 Motherboard
Front panel microphone is not working. - Asrock ConRoe1333-D667 Motherboard
  • 122 Answers
Check the manual and make sure the connections from the front panel speaker is connected properly to the mobo
Posted on Feb 14, 2010
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
Front panel problems
First of all you check on your motherboard for front panel wiring ok or not. Just like this 0a115484-cd2a-4776-a9d2-308bc688c789.gif
Then change your audio driver application setting. Ex. disable front panel detection or AC 97...
Still don't get sound via front panel you have to check your BIOS setting under titled onboard chip configuration.
Jan 19, 2014 | Computers & Internet
Sir, I am 58 yrs old having an interest in computers.I have Two Problems.I hope you will extent your help with your knowledge and expertize in solving the problems. 1. The front audio panel when fitted...
As per your information, there might be some problem with front panel microphone.
1(a). please check the internal cable for audio from motherboard to front panel. if possible change the internal cable.
1(b). If not avoid using the front panel and use the extention cables for extending from back points of speaker connection and microphone connection. just like usb extention cable you will find the audio/mike cable extentions can be found in local electronics shop. so that when ever you want you can connect speakers or headphone and also microphone.
2. For entering to BIOS, use either DEL key or F2 key when you power on the pc. In that you can see all the features. -
May be this helps to you.
Jun 17, 2011 | ASUS P7H55-M LX Motherboard
My microphone is not working but the laptop has one that is built in
try to configure your sound card may be the microphone is set in front/back panel. and make sure microphone is unmute.
Aug 23, 2010 | Dell Inspiron Mini 10 Notebook
I plugged my Microphone in the pink slot and it doesn't work on Vent, nor does my computer picks up the microphone
Make sure the Front Pink In is enabled.
Find the Volume icon in your Taskbar (little speaker, Right Click - Open Volume Control) or in Control Panel / Sound and Audio Devices. Find Device Volume / Advanced and uncheck the Front Pink In Mute box and slide the volume UP.
Mar 24, 2010 | Dynex Voice-Certified PC Desktop...
Ibm 8303-21g front audio pin configuration
Manual usually has diagrams and pin configuration for your system.
If you don't have the manual go to their web site and take a look.
Feb 06, 2009 | IBM Computers & Internet
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Pavilion PC Notebook Verve dv2000 Microphone
yaa you have to set your microphone valume but first check if you are getting right connection.
In front panel jac there are three Jacks
  • The Left on is for microphone, i.e. you should insert the microphone node in it.
  • The second 2 jacks are for speakers you can insert speaker node in any one or both.
Try this I think it will work, otherwise ask me and let me know whats going on.
Gud Luck
Iqbal
Apr 16, 2008 | HP Pavilion dv4000 Notebook
Asrock ConRoe1333-D667 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
