Question about Philips 60P8341 60" Rear Projection Television
Color stays red all the time. all 3 bulbs are
Color stays red all the time. all 3 bulbs are lite but still everything is red. any suggestions other than calling a repair tech??
  • Philips Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
color stays red all the time.  all 3 bulbs are - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
Sony we655I put a bulb in sony wega we 655 and it won't stay on when you push on button and thr red lite flashes three times in succession
It sounds like there's an issue with the power system in the TV. This can indicate either the bulb replacement didn't work, the wrong bulb was used, or there may have been other power issues that the burned out bulb might have been a symptom of.
Mar 16, 2011 | Sony KF55E200 TV
The tail light assy is a 3 bulb on a 1996 mustang coupe. Only one light bulb is illuminating in each assy. There appear to be at 2 additional bulbs per assy that are not illuminating. In addition the...
This is the only diagram I could find for tail-lamps. The top wires are voltage, the bottom wire is ground. The brown color wire is voltage for tail lamps. The other color wire is turn or stop, depending. The turn and lower brake lites use the same bulb filament, just not at the same time. The lower brake lites are wired through turn signal switch. I don't know if diagram matches what you have? I looked at several, all showed the same thing.
Aug 13, 2017 | 1996 Ford Mustang
LOST THE LIGHT BULB [SET ON RIGHT SIDE OF SCREEN] THEN LOST BLUE
I replaced bulb on SOny XBR 60 with sony brand bulb about six months ago. everything was fine, then a week ago it seems that I lost the "red" portion of the color. Any suggestions?
Jul 23, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Red keeps going out but there is a new bulb in place.
red light keeps blinking on and off but the tv isnt turning on
Jun 02, 2009 | Toshiba TN61X81 61" Rear Projection...
Sony Wega Model KF-50WE610 won't come on
The pop you heard might have been color weel braking and it might be stuck color weel dont move tv wont come on color weel is inside of engine you would have to replace whole engine 900-up
May 23, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Visioneer 9220 scans red
The scanner bulb is getting to hot. Check power adapter voltage output or replace if is getting to hot
Apr 08, 2008 | Visioneer OneTouch 9220 USB Color Scanner
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Philips 60P8341 60" Rear Projection Television Logo
372 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
