Question about Whirlpool Calypso GVW9959K Top Load Washer
How do I fix the washer when it flashes ld?
How do I fix my Whirlpool washer when it flashes ld?
  • 572 Answers
Change the pump if done so clean it. theres a new upgraded pump
Posted on Feb 06, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
Feb 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool gold catalyst it will not drain water, reading says LD?
LD = Long Drain...  "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  could be a bad pressure switch, the pressure hose, the water pump..  those are good places to start.
Jul 31, 2010 | Whirlpool GSW9800PW Washer
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code
taking too long to drain,there is somthing in the drain pump intake or the drain hose is kinked. there could be somthing in the pressure switch hose makeing it think it still has water in it
Dec 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
LD flashing
Usual causes are easy to check:
1. Unplug the washer and clean the pump strainer. It is located between the drum and the pump, and will be attached to the drum with a rubber hose.
2. Dump your drain hose into a bucket to remove any build-up in the drain hose. If possible, run an empty load, with the drain hose pointed outside.
Best regards, --W/D--
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing LD
ck pump original pump clipped to bottom of pump motor new style pump has 4 torx screws in bottom and can be cleaned ..old style was bad for stripping splines in pump at motor end
Jun 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
