Question about Samsung PCL5415RB 54" Rear Projection Television
Power light is on front of unit, but will not turn on
Turn signals won't work
the flasher unit maybe problem but you need all lights working like brake lights.
if flasher light stay on front and rear then the flasher unit is defect or no power to unit have a look
hope it helps rate it
Oct 05, 2013 | Pontiac Firebird Cars & Trucks
Changing front turn signal from stock to after marker not enough wires
put live wire from indicator to flasher unit, and same wire to ignition park only one way will connect, key on, power to indicators flash unit, key on park, power direct to indicator bypassing flasher unit, other wire is the earth
Mar 10, 2013 | Motorcycles
When I press turn on button on my pc tower, green light does not turn on, so windows does not load, I have to turn pcu manually off and on several times to get windows to load. Thank You
Well,
It could be something as simple as the power button on the front of the unit, to the power supply inside the unit. If you are feeling brave, you can take off the front panel and try to engage the power switch manually
Jan 02, 2011 | Computers & Internet
My samsung DVR 4 channel will not turn on. There is a red light in the rear inside, but the unit itself will not come on. I noticed a beeping sound coming from the unit every 10 minutes or so.
Will it show any lights on the front display at all? If there are no front light, then there may be a power problem, try plugging the unit into another socket and if the red light inside the unit returns and wont display anything else the I suspect that it may be a burnt out power pack, which will need to be replaced by a service technician due to the high voltages with power sources.
Hope this has helped :D
Any more questions please just ask!
Nov 23, 2010 | Samsung 4 Channel Dvr
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
How ca my ps3 from ireland work in canada on a sdtv?
You need to reset the video settings back to factory. This can be done by turning the unit completely off(Hold down the power button in the front until you see a red light. Once the red light is on turn the switch off in the back. If you do not turn it off in this order, and just turn the unit off in the back it can corrupt your hard drive!). Once the unit is completely off, hold your finger down on the power button in the front. While continuing to hold down the power button in the front, turn the switch on in the back. After a couple seconds you should hear several beeps. This confirms that the video settings have been reset. Don't get discouraged if this does not work on the first try, it sometimes takes several attempts to work. If you have any other questions feel free to contact www.wiredextreme.com.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Power to unit but will not turn on.
You need to replace your STKs Both of them they are convergence ICs and do control startup. they are big black ics STK392-040 also ck (2) resistors-- RZ142 3.9ohms RZ145 3.9ohms .To order Parts Call Electronix 1-800-223-3205.
Dec 30, 2008 | Samsung HCN529W 52" Rear Projection...
KDF-42WE655 Wont power up
you need to buy a bulb for the tv its about 179.00 on ebay
Nov 07, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Str reg.
No need to take the front screen out. The power deflection board is messing up with that red light.
Nic
Aug 19, 2007 | Toshiba 65H81 65" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
