Question about Emerson Cf4500 Ceiling Fan
I cannot get the down light on my Emerson CF4500 to light
I cannot get the down light on my Emerson CF4500 fan to light. The fan will only light the up light. For example, when I hit the Emerson SW350 remote switch to turn on the down light on my Emerson CF4500 fan, the up light indicator on the SW350 switch lights up and the switch turns on the up light instead of the down light. If I hit the select button on the SW350 switch to switch over to the down light, the down light indicator will light up. If I then hit the button on the switch to turn on the down light, the indicator on the SW350 switch changes to the up light and it turns on the up light. Is this a faulty SW350 switch or is there a problem in the control module in the fan?
    Top Expert:
  • Emerson Master
  • 40,215 Answers
Could be a faulty receiver in the motor housing
Posted on Mar 29, 2017
SOURCE: Emerson AV101 System
there is a reset button on the back u will need a ball point pen to push it in and it is very small.
Posted on Nov 19, 2007
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
There you will find all needed information
Posted on Jul 05, 2008
  • 9098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Posted on Sep 02, 2008
  • 1077 Answers
SOURCE: I have an emerson flat screen that will not turn on ? The red stand by light comes on, but when you hit the power button the green light comes on then shuts off quickly and the TV will not come on?? A
Try leaving the TV unplugged for 30 mins so the TV can reset itself.
If that doesn't work, most cases with the Emerson TV, the Inverter Transformer goes bad on the backlight Inverter Board. It's what powers the screen for your TV. If it can't power up the screen, it automatically shuts off. Basically, they call this "Protection Mode" with this happens.
You can get a replacement backlight inverter board at this web site link:
Just make sure the board number matches your board.
If it fixes the problem and you decide to throw your old board in the trash, I would like to keep the damaged board if possible. I want to do some research on the board to find out what really causes the transformers to go bad. Here's my e-mail
Posted on Jun 03, 2009
  • 672 Answers
SOURCE: How do I get the switch code for an emerson ceiling fan?
There are switches in the remote and in the switch housing. Check this Emerson link for specific instructions.
Posted on Jul 01, 2009
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
I have an emerson ceiling fan with a light AND emerson SWQSRR controller.I can't figure out how the SWQSRR controller could control the fan and light seperately by only using 1 yellow wire?
Because it's a wall remote. Remotes will work fan & light with one hot wire. You should have a receiver in the canopy of the fan.
Oct 18, 2015 | Emerson Dryers
Our four light Emerson fan has two lights (across from each other) that do not work. They appear to be connected by the same blue wire.
If you have a pull chain I would check that switch. If not check all your wiring and make sure everything is secure.
Sep 11, 2010 | Emerson Fans Dryers
I have a sw102 fan/lt switch that don't light up or operate and it is wireless
Make sure that there is power to the fan and that the fan and light are turned on. Also, make sure the battery in the switch is a good one (charged). Hopefully this will help. Good luck!
Mar 03, 2010 | Emerson Fans Emerson SW102 White Battery...
The microwave is not coming on. The numbers are
hello mam
the microwave heater has gone wrong please replace it then it will be working good.
Sep 14, 2009 | Emerson Fans Emerson MW8115SS Microwave...
Emerson Cf4500 Ceiling Fan Logo
53 people viewed this question
Top Emerson Dryers Experts
Jim Thurston
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerson Dryer Expert? Answer questions, earn points and help others
