Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Replace door spring on model fdb636gfr5 dishwasher
How do I replace door spring on model fdb636gfr5 dishwasher? Can I get a diagram?
3 Suggested Answers
  • 1314 Answers
SOURCE: I need to replace the Door Springs
if you just need to install springs pull the bottom kickplate can do it there only two screws
Posted on Dec 30, 2007
Maytag317
  • 1136 Answers
SOURCE: I have a frigidaire quiet clean I dishwasher model
Hi, The easiest way would be to pull the d/w washer out of the cabinet about 8". Try removing the kick plate below the door and see if you can access the springs ok. Here is the part # 154430501. I would replace both springs while you are in there.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
The door retract spring has broken what is involved to replace it M/c new in Nov2008
Usually removing the bottom panel, side panel or rear panel.
Unhook the old one. Attach a loop of very strong string to the loop on the other end and stretch it to the other fixing closest to you. For safety wear goggles.
Google
make model spares
you will end up on a site like this
http://www.reliableparts.ca/catalog/Dishwasher-Parts
and specifically, like this with a parts diagram. NOTE: this may not be the part for YOUR machine.
Dishwasher Door Spring
Nov 24, 2015 | Dishwashers
Reolacing door springs
Most dishwashers share the basic design either between models or between brands. There are even cases of the same model being sold under different brand names. Below are two (2) common door assembly diagrams with parts placement. Please check which closely resembles that of your unit.
This image was originally posted here.
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Dishwashers
Whirlpool dishwasher model du810dwgu1 Dishwasher door won't latch
Either door latch is broken or the springs are too tight
Need to check the actual parts.
For door latch see items 9 and 10 in this diagram
http://www.appliancepartspros.com/frame-console-parts-for-whirlpool-du810dwgu1.html
For spring location and adjustment see item 28 in this diagramhttp://www.appliancepartspros.com/tub-assembly-parts-for-whirlpool-du810dwgu1.html
Apr 02, 2014 | Dishwashers
Candy 650 dishwasher.....opened door and loud cracking sound, door now very heavy. Think door spring snapped, how do i get to it and where do i get spares from?
The door springs are attached to the bottom of each side of the door. You have to pull the dishwasher out far enough to see the area or all the way out if you have sides on yours. It hooks on the door and another hook on the washer frame.
Post your model number HERE to find a diagram and parts.
Jan 25, 2011 | Candy 24 in. CD650 Free-standing...
I have a Bosch dishwasher, model SHU9915UC/U11. The spring mechanism on the detergent door cracked, and I bought the part to replace it. I took the front cover off of the dishwasher to determine how to...
Hello! This is Guru...Saailer...I have your information...Due to size limitations I'll need your e-mail address in order to send it to you...Send an e-mail to me and I'll send an exploded view diagram and parts list...Guru...saailer...
Saailer@ec.rr.com
Jan 23, 2011 | Bosch SHU9915UC Dishwasher
What keeps the door from dropping fast? Is there a retention devise to counter balance the door? What part(s) could break and cause this problem?
There is a spring at the bottom of the door on each side.Pull the dishwasher out a few inches and you should see it from the side. Parts 1,2 and 3 are the hinge and spring on this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=109266&diagram_id=236108#d236108
Mar 22, 2010 | Frigidaire 24 in. FDB836GF Built-in...
KITCHEN AID STAINLESS DISHWASHER MODEL #kuds02frssWe just replaced both springs in the door and the latch mechanism and the soap dispenser that still does not work. Our door will not stay shut. MY HUSBAND...
Hi.
Your husband must check wiring harness from electronic control to door lock solenoid.
The solenoid should also be tested reading Ohms with a multimeter.
Here parts and diagrams: KUDS02FRSS
Dec 02, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Dishwasher door, too much spring
YES after you have the panel installed it will open and close much better the factory sets the springs on your model tight so when the panel is installed it can weight down the door after the panel is install you may have to readjust them tighter again
Feb 23, 2008 | Dishwashers
Detergent dispenser
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Aug 08, 2006 | Magic Chef CDB6100 Built-in Dishwasher
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
99 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
