Ac problem hi there, iwant some help in duct type air condition (trane)60000 BTU .when i was gave the out door freon i recognized that the high pressure fans were off and the compressore was on ,so i turn off the air condition for seconds then turn on i found that the high pressure fans run for one minute and then turn off and the compressore still running ,so what i shell do????
  • 456 Answers
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Posted on Feb 06, 2010
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
AC dont work and heater door seems stuck in the heating position
You seem to be on the right track. You can manually jump the compressor clutch, to come on and see if she blows cold air. Follow
the compressor clutch wiring back to the evaporator. There should be
a 2 wire harness there with a connector. Take the wiring connector off
and install a small jumper wire between the 2 terminals. this should
automatically make your compressor clutch engage , regardless of
freon level or head pressure switch condition. You may also have a
vacumm leak, which controls your heater damper actuator. Check all
the vacumm hose in the engine bay and try to locate the damper in
the dash, so you can manually pull the damper open, to see how it
helps your situation.Good luck.
Mar 29, 2010 | 1999 GMC Sierra
Hi there, iwant some help in duct type air condition (trane)60000 BTU .when i was gave the out door freon i recognized that the high pressure fans were off and the compressore was on ,so i turn off the air...
I hate to say this but it sounds to me like you need a professional. You may hear some other advice but it's not safe for anyone to work on the outside compressor unless they really know what they're messing with. The fire and death by electrocution risk is very real.
Feb 06, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
AC unit blows cold on passenger side and warm on driver side.
There are separate blend doors for the passenger and driver's side. The blend doors divert, not block air, so it is unlikely that the blend doors are the problem. You need to check the operation of the re-circ door.
There may be some more duct work that attaches to the heat/air conditioning housing under the dash, that supplies air and or heat to both the driver side and passenger side of the car, the duct work on the driver side may have come disconnected.Check this also.
Hope this helps
Thanks
Smith.
Sep 11, 2009 | 2008 BMW 528i Sedan
Trane Heater A/C Airflow Control
i had a similar problem, and a six inch duct and inline booster fan didnt help, the room was just to far away from the furnace and ac. to save energy, i use an oil rad in the winter, and a portable ac in the summer, it works great.my house is a back split, so its a common problem. in the summer, all downstairs dampers should be closed to push the cold air upstairs ,as it will come back down anyway and the basement is cooler as it is. so if you have 4 flores, you close the bottom 2. bungalow you close the basement
Jul 22, 2009 | Heating & Cooling
AC Cold air but no volumne of air flow
Please check for any blockage and in the ac duct, IF the duct is clean you need to refill the AC gas and get it serviced as the AC thens to weak over the years ........................
good luck................
Jun 01, 2008 | 2000 Jeep Cherokee
Fair price to fix central air conditioner leak & refill with freon
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Apr 18, 2008 | Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
