Sony Projection TV - No Picture
Sony 46" videoscope color projection tv using antenna and digital box. Picture is normal, good quality most of the time. Picture will be normal, then screen will suddenly go black with snow accompanied with static noise sound. If left alone after a while the picture will pop back on. I have checked all of the cables and connections for shorts or looseness. Moving the connections and cables I am not able to cause the picture to go out or come on. It is unpredicatable and may stay fine for on a long time (several hours). Any assistance would be appreciated. Thanks,
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
  • 4234 Answers
SOURCE: TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Posted on Feb 10, 2009
Benimur
  • 6966 Answers
SOURCE: Phillips 55'' rear projection tv model #55pp970104
Hi and welcome to FixYa,
To my understanding all that you need is which jacks of the cable box has to be connected to which jacks of the Philips TV. Limiting conditions are:
  • can not use the standard Antenna A connections since the Philips would display a pink video;
  • you do not recall how and where they were connected to effect HDTV 4 setting in the Source Selection.
Your additional information of 'AUX 4 HD Y PbPa connection' is significant. It tells us that HDTV 4 is used for component type of inputs; therefore the cable box has to have similarly component level, meaning at the rear of the cable box, there should be a similar Y, Pb, Pr.
If none exists (Y, Pb, Pr at the rear of the cable box), determine if it has a composite (yellow jack) and if a similar one exists in the Philips TV.
Alternately if at all possible, post back with photos of the rear/connectors/ jacks of both the Philips and the cable box or list them in the comment box.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
falsafat
  • 31 Answers
SOURCE: Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Posted on Apr 12, 2009
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
Oct 27, 2013 | Toshiba 46H84 46" Rear Projection...
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
Color on tv are off green red blue as if it was three D. HELP!!!!
Yes, its problem of convergence out chips failure, replace two big black convergence out chips in TV to fix the problem.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then you can fix this TV issue by yourself or ask local tech to repair it.
Thanks.
Jan 15, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Tv sounds like motor running when turned on
It is no doubt the color wheel. Replace it soon or the ballast will also go out.
Oct 21, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
46" screen with an <8 x 11 picture!
you should contact samsung and inquire as to poss.warranty defects of this item
Aug 23, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
Sony TV KP-46WT500, 46" Rear Projection TV , colors mixed up
You have a pair of Bad STK392-560. replacing these will definitely fix the set.
Best regards
CircuitCity
Dec 19, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
