Question about IBM ThinkPad T43 Notebook
Running windows XP and it does not let me print wirelessly yet it sees the network and the printer is set on "share".
  • jimg5464 Feb 15, 2010
    I am aware of settings for sharing and checking the print Queu.
    Thx!
  • 1,428 Answers
Can you delete all network configuration and restart the system afterwhich you can reconfigure to the network again.
That should fix it because it worked for me at the Office yesterday.
Good luck.
Posted on Feb 15, 2010
  • Titilayo Sodipe Feb 16, 2010
    Just follow my instructions.
    President:
  • 4,070 Answers
Hi, try to check the printer tasks if there are pending docs to be printed but did not print, if there is, then try to cancel them all and try printing again. hope this helps
Networking issues
Sounds like your printer isn't configured for "sharing." Go to Control panel > Network and Sharing Center > Choose homegroup and sharing options. Make sure Printer has a check mark.
If you have any other computers, check them to see if you can print from them.
Jan 14, 2012 | HP Photosmart C4180 All-In-One InkJet...
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Vista and xp network
  1. All computers should have installed and enabled file and printer sharing, which you can see and change in the properties of the network connection.
  2. All computers should have enabled file and printer sharing as an exception for the Windows firewall.
  3. Sometimes you need to install the IPX protocol on the network connection.
May 05, 2009 | Computers & Internet
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
I have an HP c4180. My pc is Windows xp. Would like to print through my wireless hub. Internet and printer are connected hard to the hub. PC won't see the printer.
I have the same printer, & it prints fine on my desktop pc but to get it to print from my laptop wirelessly I just had to enable printer sharing on both pcs, & then when adding a new printer on my laptop I just had to set it to print over a network. the only problem I get is I have to select the printer when starting a print session.
Jan 02, 2009 | HP T30 DK411AABA Network Terminal
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
IBM ThinkPad T43 Notebook Logo
19 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
